AlwaysFixingSomething
- Joined
- Feb 27, 2014
- Messages
- 568
You're making a lot of noise on this thread about licenses vs. certifications and blah, blah. There are many "licensed" and/or certified electricians that can do as poor quality work as the 'homeowner' that you categorize as a hack in a generality.
If you would like to help the OP in getting someone to pull his permit and do his work so he can move into his new garage, then do that. If you have information that the electrical contracting business is so busy now that they simply overlook a garage job then show the OP that. All he wants is help in getting his garage done. If he has to get in line or fill out a lottery form to get a sparky, he probably would at this point.
Or if you have any suggestions on how the OP can move this along I bet he would be very open to hear that. I think that's why he started this thread. He certainly did not indicate that he was going to watch youtube and then wire his garage.
I think a homeowner has the right to enjoy and improve his property. If said homeowner has done all the due diligence to get an electrician approved by the AHJ and cannot get his work down in 5 months of waiting and calling people, that he should wire the goddamn garage hisownself with or w/o the help of his relatives and call the inspector. If he is failed if and when all the work is up to code, I'd take that case to court.
I was simply replying to a few different posts in this thread. If you think it's noise and felt the need to add your own noise...i don't know what to say. It's called a discussion forum for a reason.
At least most areas are catching on and requiring only a licensed electrician to pull permits and do the work.
Job to small?
