Aren't these standard?
pop pop
Virginia
I'm trying to find 2, 5/16" - 24 tpi (fine thread) x 3/8" L slotted round head machine screws. Seems everything now days is blister packed and stops at 1/4-20. Anyone know of a source?
BFBOB
Not for sure, but you might try the usual suspects, McMaster-Carr and Fastenal. Good online sources - and maybe Enco, if as I'm guessing these are used in bolting down machine tool fixtures?
Good luck.
Trucky
Not really... they're harder to source than you might think. I'll look around and see what I can find.
As far as 5/16-24 slotted round head machine screws go.. McMaster is out. MSC is out. Fastenal is out. Meh.
MSC has a metric truck load of 5/16-24 SHCS, if those are acceptable.
P
pop pop
Virginia
These are replacement fill "plugs" for my floor jacks. Never though this would become a problem! I searched the usual suspects first, and every other pretender on the net. I may relent and use the hex or star, but really want the slotted screw if possible.
Trucky
Why not get a SHCS and JB weld on a round head? Heck, a piece of 5/16-24 all-thread would do you just fine.. just get a few 5/16-24 round head machine screws to "frankenstein" the heads from.
If that's really what you're after.
Stuart in MN
Minneapolis
The Ace hardware down the street from me has a pretty good selection of screws and bolts in bulk, if you have one nearby I'd try there.
P
pop pop
Virginia
I've done a pretty fair search on line and been to 3 autoparts stores, 2 hardware, and 2 big box stores so far. Nothing even close. I'm really shocked. Seems such a simple screw! Thanks for the substitute ideas so far.
PETE14
Denver, CO USA
What kind of jack (manufacturer, year, ect)? Any chance it could be sourced straight from the OEM as a spare part?
LeonardY
Southern California
I had problem finding a slot headed screw for a vintage yacht. I ended up taking hex head bolts turned and shaped them into round heads with a file on the lathe. Cut a slot with a slitting saw. Worked great.
P
pop pop
Virginia
Thanks for all the offers. We've sent an email to Nutty. All the other vendors offered have been contacted with "NO". Rounding a hex and slotting it was my thought as well, just didn't want the job. These are for obsoleted Walker jacks. I'll talk to Hiball. He's probably got a solution. Just seemed such a simple bolt need that should be standard at the local hdw.
