Armored cable
Twogrn
Can you run 3 sets of 14/3 w ground in a single armored cable ? Total length of run is about 12'
Thanks in advance for your input.
ishiboo
Oshkosh, WI
You mean steel flex conduit, correct?
It would depend on the diameter of the conduit.
T
Twogrn
Yes I know, I was thinking about 1" metal flex, not sure what code calls for on the number of conductors aloud in it.
larry_g
oregon
When you say 14/3 with ground are you referring to a Romex (NM) style sheathed conductor? Or are these conductor single conductors like THHN? It makes a difference.
lg
no neat sig line
alfredeneuman
Fullerton, CA
The way to figure this, because the are no diagrams, is go with (much) math involved "Chapter 9 - Tables".
For 1" Flex:
Suffice to say that the 3 cables need to be a little less than 3/8" each, in any dimension, to be below the 40% fill requirement for more than 2 cables
OK. Thanks for the correction. I've been told numerous times and also I've seen other posts about "romex" not being allowed in conduit.
I stand corrected. :thumbup:
Tommy
Yeah it drives me nuts when people say that. I dont know where that ever came from but its WRONG!
And im sure pattenp and Norcal agree
rockwithjason
Las Vegas
it's allowed in conduit but not in wet locations ie underground. you need to go to uf or some other wet rated cable for that. some people claim that heat is the issue but it makes little difference.
Eriehunter
Not to hyjack this thread but, is there a tool made to cut the armor - other than a hack saw?
Yes a roto split.
Or in the larger sizes I use a hacksaw or porta band.
In the smaller sizes I "break it" a little longer than needed and use tin snips to cut the extra coils off.
