cullen
I recently installed Armorpoxy SPGX coating in my new shop. Ill offer my quick review.
With 720sq ft. of concrete to cover, I bought 2 gallons of clear because I wanted the industrial look. It arrived within a week of the order.
I degreased, pressure washed, and etched the floor. When you do that, you really see all the imperfections. It made me sad to see that on a new slab. I should have gotten a 3rd gallon. The floor really absorbed that first gallon and it was tough to get a second coat. I didn't coat the stem walls because i ran out of product. That's OK, I'm installing rubber trim anyway.
It rolls on easy and you have plenty of time to roll it out. I worked in 2'x6' sections. This is a must because you cant see what you already rolled on the second coat. While applying, there is a smell but it isn't bad. In fact, the smell was gone withing 24 hours.
The coating looks great and the floor looks "wet". After 30 hours of drying, I started moving equipment in. Even after installing pallet racking and moving a lathe in, the floor only showed some small surface scratches.
So far, i would recommend this product. BTW, If you are picky, get a color coat unless your concrete is perfect.
