Arts & Crafts Garage
A
AgDieseler
My truck and car are the reason the garage exists.
It's a space for doing, and lately I've been spending a good bit of time on the '70 R/T. It's fairly complete - interior, trim, mouldings, lights, glass, suspension, drivetrain - really a rolling shell with no engine or transmission; perfect for my purposes.
It arrived at the shop filled with three things: lots of parts, copious amounts of rat piss and ****, and a rattlesnake that had taken up residence in the truck. No doubt it wanted to be close to a reliable meal. The snake didn't wait long to move out, and truthfully I only ever knew he was there from the shed skins in the corner of the shop and the trunk.
The interior was a biohazard, and I ordered the 3M mask and glove setup and got to cleaning the emptied car. I filled my shop vac several times and finished with a thorough rinse of the floor and inner door panels. It was funky.
Having never disassbled a Mopar, I started cataloguing and bagging and tagging the screws, clips, brackets with detailed notes as to how they went together and where. The reprint service manual was a useful guide. I should also say that every project - garage, house, car - is a chance to work with friends and family. Here's a buddy helping me take out the suspension and get it loaded up in the body cart:
Disassembly should move along nicely from this elevated height:
The objective is to build a car that will drive across the country and perform competitively against whatever monochromatic German machine it might encounter, as well as more recent iterations of American pony cars.
Initial plans are to maintain the solid rear axle and torsion bar front, making thorough upgrades to the unibody such that we create a rigid and predictable chassis that delivers power to ground and doesn't just evaporate the rear tires, which will have the largest contact patch we can reasonably fit in the wells. Big brakes, precise steering, a well sorted suspension, around 600hp, an overdrive, and a target dry weight of 3700 lbs are all part of the plan. Maybe I'm aiming high.
Performance and long range comfort are the priorities, and in that order. There is a budget, so it will be built by hand and not a checkbook, and after stripping part of the rear quarter, it looks like I'll be placing at least one order with AMD for some new sheetmetal.
Delayed updates, but the space has seen some additions in the form of a Quincy QT54 and a Hobart 210MVP; each have transformed the method and speed at which I work on projects.
Now, back to sanding.
David
A
AgDieseler
Re: The Willomet Garage
We're still very pleased after 6 years. The granite has proved to be a great base for the stones. We fertilized and spread grass seed, and that has taken well, too.
David
ambenz
NW Chicago Suburbs
Well David, pretty cool interior walls, I like it.
Bet you wish you could have built it deeper...can you add a future bump out in the back to allow a bench and some essential storage? Looks a little cramped for working on projects.
A
AgDieseler
Thanks for the comment. I remain pleased with the footprint of the shop. Quite frankly, I'm inspired by smaller setups, and their modular approach to work space and storage.
There's an editorial in this month's Hot Rod where David Kennedy extols the virtues of a small work space - 308 square feet being his estimate for all you really need to build a car. Not sure that's my magic number (for the record, my shop is 576 square feet), but it is a valuable thought experiment.
David
A
AgDieseler
Going back through some older photos, I figured these would better detail the interior wall project that I had only summarized to this point. Like most of my projects, it starts with a budget much smaller than I'd like. To stay in keeping with the Craftsman style, the walls needed to be shiplap. New shiplap is expensive, and reclaimed shiplap is very expensive. Enter Craigslist.
I searched for roughly 4 months using the following terms: shiplap, siding, pine siding, 105 siding, R19, etc. Like most CL searches, 90% of the results are not what you're looking for, but in that 10% is where I found a bunch of 105 siding taken off an old farmhouse in Pottsboro, TX:
Cataloged and organized, I did a rough calculation of how much I'd gathered. I'd also located some very pretty East TX blue pine, but it was only 20 boards or so. In total, I had enough to wall 1/2 of the garage with reclaimed material. I spent 2 weeks negotiating with the lumber yard for the rest. Here's what I ended up with:
Installed face down, 105 or 117 or edge and bevel looks like shiplap, which is plenty authentic for me. Along with a few rolls of unused R19 off a job site, I was coming in just under my already small budget, and taking time to acquire materials spread the job cost over several months.
I started insulating the East wall in September, and had finished the three main walls by Thanksgiving:
Small details were wrapped up before the year's end:
During work on the West wall, I temporarily mounted our Level 2 car charger on a reinforced piece of 3/4" plywood so we could continue to charge our Chevy Volt during the project:
Fun fact, that temporary charger mount was originally a temporary wall material covering to protect a power cable, and then a temporary scaffolding deck to help us caulk/prime/paint the outside of the garage, and after this project it became my temporary workbench. I then permanently gave it to a friend who needed a good work surface.
With the construction of each wall, I had to shuffle all the stuff in the garage in order to make room. Car parts, furniture projects, holiday decorations, things you've moved too many times and need to sell or give away. We call it "pile shifting," and I wanted to do less of it. So, after a garage sale and donation bonanza, we picked up the 19"x32" shelf brackets from Home Depot, painted them flat black, and build a shelf that ran the length of the back wall. It's reinforced by three cables that tie in to the truss directly overhead:
I do wish I had more routine updates to share related to the garage itself, but right now I'm spending most of my time working on projects in the garage. I guess that was our reason for building it. That said, we do have some open items:
  • Complete decomposed granite walkway on East side
  • Build garden shed on East side
  • Remove garden tools and other 'domestics' from shop space
Here's where we are today:
Back to the project(s).
David
dhubbard422
Texas Hill Country
Great space! The doors and walls are really nice. The old shiplap add lots of character and the folding doors are an interesting solution/alternative to the typical overhead door. The Charger looks like a sweet project!
A
AgDieseler
Appreciate the compliments. Five years on, and we're still somewhat surprised at what we built.
Progress continues on the Charger. Just a few short steps away from sending it to media blasting.
David
A
AgDieseler
With the car at the media blaster, I've had a few days to pull everything away from the walls, sweep, and get things squared away.
Feels good.
David
A
AgDieseler
With the car back, I've been focusing a lot of my time on detailed component restoration and repairs. I hadn't done task lighting at the bench, and I was getting some annoying shadows.
Puck lights contrast all the straight and square lines of the shop, and I picked up a set of 6 LED lights on Amazon. Really pleased with their build quality, with how the installation went.
Ordered the DC plug and terminal strip, but ended up splicing together my own harness to keep things compact and hidden.
Since it's all DC power, I used an old toggle as my switch. That valve cover is from the 55's 216 six, but serves as a shelf for miscellaneous bits.
No more shadows, and it all looks pretty neat with the intakes on the wall.
Back to work on the car.
David
