Asphalt Costs
onempty
Hey guys,
I just got a quote on asphalt. My driveway is 560 feet and they were going to do it 10 feet wide. The price was $9600. I know its a lot of driveway but I just can't put 10K into it. Does anyone have some ideas that could cost less?
Thanks
John
Shocker
Olympia, WA
Hey John, that sounds like a deal to me. I had asphalt done, it was about 32ft wide and 40ft long and it was about $4000 for that.
Friartuck
Monmouth County, NJ
The base that asphalt companies use is usually a crushed concrete composition. When rolled, its fairly durable. Perhaps get a quote for that now and then do asphalt in one or two years. The $9600 seems reasonable to me for 560 feet long.
Tom2
I would personally just go gravel for a driveway of that size.. Unless you have the extra money to spend. You can always pave it later.
O
onempty
Thanks guys. I also thought that the price was not that bad, but its the spending 10K part that is killing me. I could do so much more that is fun with it. :)
38 Special
Irondale, Alabama
Mine is being paved this week. 1,756 feet, 12 feet wide, 3" deep. $30,000. At least there are 3 houses all going in. But, after 11 years, I am tired of a gravel drive. Bad part is I have had it quoted by the same person 3 previous times. $15,000, $22,000, $27,000 over 7 or so years. Asphalt just keeps going up. At least here (Alabama), it did not go down last year when petrolium prices did.
weicm3
Hey guys,
Thanks
John
does that include removing the existing driveway and prep. work? I was thinking about replacing my cracked concrete driveway. one company quoted me about $20K for my 100ft. (12ft wide in the first 70ft and 25 ft wide in the last 30ft). for 560 ft, $9600 sounds a steal.
mybuickgs
Kansas
I had a 1/4 mile driveway with rock for about 10 years. 3 years ago I took the plunge and wrote the check for asphalt. Although, it seemed expensive, I would say its better than buying a toy. It is so nice for your cars to be clean and not turn into a rattle trap in a few years.
Spend the money you won't regret it.
foss
On. Canada
I don't think you'll regret it either. You'll wish you could have afforded years ago.
That's sound a great price for that size of driveway to me.
WVBrady
WV
My driveway is about 300' long. Part of it is steep and would wash badly when there was a heavy rain. Grass grew over the gravel in the middle and I just poured concrete in the track. As someone else mentioned, I just wanted to not have any mud that would rust out my fenders. I poured it pretty thin, so it cracked, but it is better than it was before.
nate379
Palmer, AK
I just had mine done this fall and it was ~$5300 for 2000 sq ft. $2.65 sq/ft
OP your driveway size would have been almost $15k for me to get paved here, so I say it's a smoking deal!
thammel
Maryland
I'm in northern Md and had my driveway done for just a little under $2/square foot last year. Get good recommendations and shop around.
Tom
O
onempty
Thanks guys. I am going to talk to him and see what we can work out. Right now it is gravel. That price is for all work to be done. So I guess I am going to **** it up and have it done.
Thanks again for all the advice. This forum really is great.
IONH
Central Massachusetts
Are all the ~<$2 to $3 prices for repaving existing driveways? I have a driveway which is approximately 32' wide by 24' deep. It is currently paved but it has settled and there are a few bumps from rocks (I assume) which must be below the asphalt.
What do you think I should expect to pay knowing there is likely some below ground excavation which may need to be done to get a better base this time around.
I bought the house about 2.5 years ago and the driveway does not appear to have shifted since then. The garage itself is about 35 years old but I do not know how old the driveway is.
Ducatiman
SE Mi
Be careful of good deals...I had a company that was in the area come by ansd do my apron for 1.00 A sq foot...up to 2000.00...His work is ****!!
He has since gone OOB and IMHO he deserved it..
I was not an educated consumer so it is poart my fault..
Next time it will be done right.
MIke S
1996 Ducati 900SSCR
2005 ST3 Ducati
Brad Beam
In my area that is probably a couple thousand high. I don't know all your details like how much grading is needed, do you need additional stone etc... Make sure you ask for a written quote specifying materials, quantities, and in place thickness a sketch of the project is also desirable to make sure you and the contractor are on the same page
Snap50
New England
We had crushed stone dust and I got tired of it tracking in the garage and wanted to use a snow blower on the tractor. There is nothing like a Bituminous driveway!
Be aware that blacktop is made with oil, so if you see a big drop in the price of crude, make a move on the paving.
mpraddict
Central Ohio
I did my drive 3 years ago when oil prices were high. At that time I priced both concrete and asphalt. Concrete was actually cheaper....
red
Hudson Valley, NY
Wow surprised to see concrete cheaper. . . Lots of energy goes into making and transporting concrete. With the Backtop does the quote include two layers? My first driveway 1500sq was just one layer of 3/8" got a good ten years out of it but started to crack within 5 yrs from the freeze cycles. Was cheap, no money and sick of the dirt/noise/dust/ and maintence of gravel. New driveway is two layers, first layer 3/4" binder with a top coat of 1/4". Expect it to last 20-30yrs. At the time the contractor was screaming about the cost of oil hitting $50 a barrel! Definitely find out how thick your finished driveway with be. Thick > lasts longer and more material. -Ed
Oh $8000 for 3000sq - 3yrs ago
amuffly
Wichita, KS
If you don't want the dust of the gravel you could ask the asphalt company if they would sell you a RAP driveway. RAP is Reclaimed Asphalt Pavement and will go down just like gravel. They will spread it out, water and then roll. Should offer a nice solid drive for a lot less money. I work for large US asphalt paving company so if you have any questions let me know.
