Astro Pneumatic Tool Company
Formerjeeper
Cincinnati, OH
Got tired of my two Harbor freight LED lights, one of which only works intermittently even though it’s almost brand new. Received my new 65 SL light a week or so ago, unbelievable how much of an upgrade it is. Well worth the price difference.
A
Astro_Pneumatic_Tools
South El Monte
The UV one? Just a similar tool, the adjustable dial lumen level and magnetic swivel base has become popular since the introduction of the 40SL.
I'm familiar with that tool and it's quite large, maybe 1.5X the size of the 65SL - but has UV light too which is cool too depending on your application.
techieman33
Kansas
They make flip sockets in .5mm increments for all the common wheel lug sizes. So when they start to swell you can maybe use a 21.5mm to get them off and not be at as big of a risk of stripping them out. They really should stop using them though. There's no real benefit other than maybe saving the manufacturer a few cents.
JJ99SS
Chris,
I'll get straight to it. I just used the 1442 Rivut Setter I ordered from Amazon this week for the first time and the 1/4" mandrel snapped on the first try. Luckly I was able to remove the broken piece of mandrel from the rivnut and it is in crooked but its serviceable. That said I've never used one before and I'm using stainless steel nuts. It went in crooked so I tried to be sure it expanded evenly behind the metal and it seems I went too hard? This may fall in line with operator error.
Since its in my tailgate I can't afford to ruin a mounting hole for my particular installation because it seems it's a one shot deal.
I'm not opposed to buying a mandrel from Amazon as they are only $11 but it never hurts to see about a replacement. Also maybe some tips? Seems that you don't really need to go full gorilla with these things. How do you insure that they go in straight? The nut sits flush to the tailgate but the threads are not perpendicular to the mounting surface, and the bolt wobbles as you thread it in.
Any help from you and even the more experienced operators of this type of tool would be well received.
Thanks!
Jim
Edit: I don't need the nose piece just the threaded part. Any way to just get that all by itself?
JJ99SS
Well nevermind about the replacement, I don't feel quite right as I'm pretty sure I'm to blame.
I just ordered off Amazon.
But I'll still take any professional advice or tips on how to properly use this thing w/o mangling it or my work...
A
South El Monte
The 1442 has a warranty, we're happy to replace broken pieces if you pm me an address.
- Spritz some lube in the arm joints so that one arm doesn't start crimping before the other.
- Ideally you would have a test piece of sheet metal you can view the back side of to determine how much umph to give it. But just setting it in the air in front of you is the next best option.
- Go slow, there's not benefit to setting it quickly. Make sure the tool is perpendicular to the work piece and the arms are both doing a similar amount of work.
- Sometimes after setting, tightening the panel/piece you plan to attach with an appropriate bolt can help align and fully seat the rivet nut if there's some question. Tightening a bolt into the nut just sets it more if there is more to set.
JJ99SS
Thanks! I’ll try that. It was a stainless nut so I thought the material would be stiffer than a regular steel one. It seems that the arms would be self equalizing, but maybe not. I’ll lube it all up and see if it helps. I’ll send a PM in a few.
Thanks!
JJ99SS
Thanks!
PM sent. At least I think it sent. Let me know if you didn’t get it.
reptilezs
Chris,
Thanks!
Jim
my best tip is use the correct size rivnut. they have different panel thickness tolerances. using one for thick panels on thin material will make it crooked
JJ99SS
Thank you for the tips. I drilled the holes in my tailgate and the good news is that the metal is thicker than I thought it would be but is still in the rivnuts specified range. Using them in 1/4-20 to mount L Track to my tailgate and the front bedrail.
I ordered the wrong mandrel and returned it. It was for the ADN14 tool. Can't believe I did that. Just waiting on a replacement to arrive in order to continue...
As for the 1442 tool itself, it does have a tendency for the handles to pull unevenly. I've lubed the joints which improved the feel. It seems a bit more refinement to the tool could result in a more perpendicular pull. I'm thinking tighter tolerances in the main body and the pulling shaft to keep the tools tendency to "wobble" down? maybe bore it out then sleeve it with a bushing or sleeve bearing to make it buttery smooth.
Don't get me wrong, The tool is fantastic, but for a noob like myself, I could benefit from not having to compensate for that. The extra refinement could push the tool over $100 but it would still be very affordable.
A
South El Monte
We now make a quick change .498 chuck and .498" bits for the Astro 4980 and any .498 air hammer.
49801
Quick Change Retainer Chuck .498 Shank
49803 3pc Chisel & Hammer Bit Set .498 Shank
- 7" long "non-turn" type slotted chisel
- 1" diameter straight shoulder hammer bit
- 1.25" diameter rounded hammer bit
Shootinok
Oklahoma USA
Ordered the Astro 7865 Ball Joint Service Tool Kit with 4-wheel Drive Adapters.
Worked GREAT on son-in-law's Dodge 4x4.
Very happy with it!
A
South El Monte
We haven't had a quality "pistol" style riveter offering in quite some time. As a company that does a lot in riveting this was severely lacking.
The 1422 Professional Micro Hand Riveter is a 8.5" long hand riveter, 25% shorter than anything we've offered before, yet requires 30% less effort to set a 3/16" steel rivet.
Perfect for tight spots
Sizes: 3/32", 1/8", 5/32" and 3/16"
torqueman2002
Great timing.
My wife has been asking me for ideas for my fast approaching birthday.
Amazon says it will be here with 1 day to spare.
Thanks!
kythri
Lebanon, OR
Chris:
Are the crimpers in the 9477 and 9478 the same?
I have a 9477 kit - was curious if you sell the Weather Pack dies separate from the 9478 kit.
Farmall450
Marengo, Illinois
Looks great.
isb cornbinder
I bought one of your pneumatic pop rivet guns. The kit did not come with the little bag of goodies. These bits and pieces may have been shop-lifted. I went back to the tool store and tried to explain my situation. I was blown off like a common thief and the suggestion was I had misplaced the parts and I want the retailer to give me another set.
OK, I understant the feelings of the retailer. So rather than argue with the ******* cusomer service guy, I did the right thing and bought another Astor Pneumatic rivet gun. My reasoning is, I can put a popular nose piece on each gun and then I will not have to change them out.
I still feel insulted. This is not the fault of Astro. I was lucky to get the sale price.
The person who appeared to be in charge was an easy on the eyes female and she was gracious, efficient and made me feel like a valued customer.
Farmall450
Marengo, Illinois
Does Astro make a buffer kit, 7", for 5/8 coarse thread?
I see the backing plate online at a few places from you, and was wondering you there was a whole setup.
619DioFan
San Diego , Ca.
I am sure if you contact Chris at astro he will take care of you. he is good like that.
isb cornbinder
Rather than edit into the last post, I will add this tidbit.
I have a selection of DYNABRADE pneumatic tools. Dynabrade is of the highest quality and made in USA. The Dynabrade pneumatic tools are 6 - 8 times more expwnsive than A-P. Are the Dynabrade worth the extra? That is a question each person will have to answer for their situation. I watch Amazon for that rare deal on Dynabrade.
ChrisLS8
And this has what to do with AP?
reptilezs
found this while riding my bike. not tough enough for the road traffic
signcrafter
Just bought a tire machine and balancer so needed to get setup to plug nail holes. Bought the astro low speed tire buffer. Have bought a ton of astro stuff in the last two months and everything has exceeded my expectations. Think the only name in tools I've spent more on in the last few months is milwaukee.
