Well nevermind about the replacement, I don't feel quite right as I'm pretty sure I'm to blame.
I just ordered off Amazon.
But I'll still take any professional advice or tips on how to properly use this thing w/o mangling it or my work...
The 1442 has a warranty, we're happy to replace broken pieces if you pm me an address.
- Spritz some lube in the arm joints so that one arm doesn't start crimping before the other.
- Ideally you would have a test piece of sheet metal you can view the back side of to determine how much umph to give it. But just setting it in the air in front of you is the next best option.
- Go slow, there's not benefit to setting it quickly. Make sure the tool is perpendicular to the work piece and the arms are both doing a similar amount of work.
- Sometimes after setting, tightening the panel/piece you plan to attach with an appropriate bolt can help align and fully seat the rivet nut if there's some question. Tightening a bolt into the nut just sets it more if there is more to set.
Thanks! I’ll try that. It was a stainless nut so I thought the material would be stiffer than a regular steel one. It seems that the arms would be self equalizing, but maybe not. I’ll lube it all up and see if it helps. I’ll send a PM in a few.
Thanks!
PM sent. At least I think it sent. Let me know if you didn’t get it.
Chris,
I'll get straight to it. I just used the 1442 Rivut Setter I ordered from Amazon this week for the first time and the 1/4" mandrel snapped on the first try. Luckly I was able to remove the broken piece of mandrel from the rivnut and it is in crooked but its serviceable. That said I've never used one before and I'm using stainless steel nuts. It went in crooked so I tried to be sure it expanded evenly behind the metal and it seems I went too hard? This may fall in line with operator error.
Since its in my tailgate I can't afford to ruin a mounting hole for my particular installation because it seems it's a one shot deal.
I'm not opposed to buying a mandrel from Amazon as they are only $11 but it never hurts to see about a replacement. Also maybe some tips? Seems that you don't really need to go full gorilla with these things. How do you insure that they go in straight? The nut sits flush to the tailgate but the threads are not perpendicular to the mounting surface, and the bolt wobbles as you thread it in.
Any help from you and even the more experienced operators of this type of tool would be well received.
Thanks!
Jim
Edit: I don't need the nose piece just the threaded part. Any way to just get that all by itself?
The 1422 Professional Micro Hand Riveter is a 8.5" long hand riveter, 25% shorter than anything we've offered before, yet requires 30% less effort to set a 3/16" steel rivet.
Perfect for tight spots
Sizes: 3/32", 1/8", 5/32" and 3/16"
Chris:
Are the crimpers in the 9477 and 9478 the same?
I have a 9477 kit - was curious if you sell the Weather Pack dies separate from the 9478 kit.
We haven't had a quality "pistol" style riveter offering in quite some time. As a company that does a lot in riveting this was severely lacking.
I bought one of your pneumatic pop rivet guns. The kit did not come with the little bag of goodies. These bits and pieces may have been shop-lifted. I went back to the tool store and tried to explain my situation. I was blown off like a common thief and the suggestion was I had misplaced the parts and I want the retailer to give me another set.
OK, I understant the feelings of the retailer. So rather than argue with the ******* cusomer service guy, I did the right thing and bought another Astor Pneumatic rivet gun. My reasoning is, I can put a popular nose piece on each gun and then I will not have to change them out.
I still feel insulted. This is not the fault of Astro. I was lucky to get the sale price.
The person who appeared to be in charge was an easy on the eyes female and she was gracious, efficient and made me feel like a valued customer.
I will remember your suggestion for another time. I have made a choice to buy a second pneumatic rivet gun. I will be installing my two most used nose pieces, one on each gun.I am sure if you contact Chris at astro he will take care of you. he is good like that.
Rather than edit into the last post, I will add this tidbit.
I have a selection of DYNABRADE pneumatic tools. Dynabrade is of the highest quality and made in USA. The Dynabrade pneumatic tools are 6 - 8 times more expwnsive than A-P. Are the Dynabrade worth the extra? That is a question each person will have to answer for their situation. I watch Amazon for that rare deal on Dynabrade.
And this has what to do with AP?
found this while riding my bike. not tough enough for the road traffic
Hey Chris:
Do you guys sell a replacement for the swivel magnet on the 40SL? Mine's all chewed up from sticking it on jagged crusty stuff. Looking at this it looks like part 40SL-11 but I didn't see any way to order it: http://www.astrotools.com/pub/media/pdf/40SL.pdf
Thanks!
Haha, that's awesome
We'll add it to the QC regimen
__________________
what new and exciting tools are you guys bring to SEMA this year?
