Attached Shop Suggestions; Layout & Finishing
D45
NW INDIANA
My Attached Garage "Build"; 65'x18'
Awesome site.........long time lurker, first time poster......
I have an attachéd20'x20' garage for vehicles.....my company vehicle stays on the street, always
61' x 15' according to the survey
I get 65' x 18', but what ever
100 AMP sub panel,with 60 amp breaker feeding it from the main 200 amp house panel.......4 of the 6 breaker slots are used
The garage is about half wired with outlets, more to come for sure
The shop lights all need to be replaced.....old school T12s
Ceiling joist are about 110" tall
Air compressor, 3 tool boxes (6' tall), band saw, drill press, welder, ladders, etc
I definitely need an attached work bench with 4-5 wall mounted cabinets
I also have a 3'x4' rolling table
Looking for layout suggestions..........I will be adding rolls of paper faced R13 insulation in one week
Still need to decide on wall panels.....NOT DRYWALL!!
I am leaning towards ribbed/corrugated metal sheetings
D
D45
NW INDIANA
Re: Attached Shop Suggestions
The "Shop" area was built by the previously owner, which was built onto the side of the house
The shop area has the front 8' tall garage door and a rear 8' tall door on the backside.......both doors are the nicer double walled insulated doors, not just the cheapo thin aluminum open channel type
The shop is divided into two sections, separated by a sliding barn door style door. The rear area will soley be used for the outside lawn, yard, and landscaping tools and items for the pool
D
D45
NW INDIANA
Got my HF welding cart put together ......works great for $30
D
D45
NW INDIANA
Found some great free stuff for the garage..... Georgia Pacific towel dispenser and many roll refills
2" thick solid slate tables in three sizes, some with steel bases and one with wood....insanely heavy as ****!!!!!!!!
One is large and is 4'x5.5'......the two others are 41"x21"
Also found some commercial grade steel shelving units for free......
D
D45
NW INDIANA
I am ready to start insulating in two weeks for my 10 day vacation
I have 78 studs (2x4) at 8'3" tall (cavity) and then another small section of 9 studs at
3'3" tall (cavity)
I am really leaning towards R-13 paper faced rolls , since they are $9.19 each
Does this make sense:
673 linear feet needed
I roll of R13 is 32' long
So I would need 21 or 22 rolls of insulation?
D
D45
NW INDIANA
The steel frame for one of the slate top chemistry lab tables I have, use threaded/adjustable feet
After some heat and penetrant spray, I took all four of the threaded feet off
I figure by the time the 200 pound slate top is installed on the steel frame, I would NOT be able to easily move it
My plan: To install some heavy duty lockable swivel casters, with the threaded stem
Going caster shopping this week.........hope to find something local with a good weight rating
D
D45
NW INDIANA
I bought a decent used drill press off CL for $100!!!
It will definitely work for my needs and the price was great
It looks like the PO only used it for small jobs and only work working
The motor looks brand new and there was not any dust or debris inside
The belts looked to be in great shape
Craftsman 137.229150
15"
5/8"
1 HP
12 Speeds
250 - 3100 RPM
0-45 degree table tilt
Motor is very quiet and other than some minor surface rust its good to go!
I had to buy new "worm gear" tooth strip on the column, which adjusts the platform up and down...........because it was broke in half and was only half of its original length.
This part was only $30
Came with the chuck key and two allen wrenches
D
D45
NW INDIANA
url=http://www.hhmetalproducts.com/home]H&H Metal Products, Inc.[/url]
Found a cheap retailer about 15 miles away for steel roofing sheets
$1.88 a linear foot
D
D45
NW INDIANA
Any suggestions on what to put where......going to start insulating Saturday!
pattenp
Virginia - USA
I take it you are in the US and I assume no building inspection was done for the shop addition. It does not look like it meets building code for fire protection to the adjacent living area. Ceiling and adjacent wall to living space should have at least 5/8" drywall.
D
D45
NW INDIANA
Yes..... in the ole USA
Yes.....building inspection was done, thanks for your concern
D
D45
NW INDIANA
Everything is insulated and stapled
Going to order the metal panels and some wood siding (to match the enclosed patio) tomorrow
I bought 25 rolls of insulation and have to return 3 rolls
D
D45
NW INDIANA
The metal panels are all installed, needed 16 sheets for the main 45' long wall
I am very pleased with how this turned out for $700.....the metal panels look great and are unique. With the self tapping screws for the corrugated panels, the install was cake.
I have 16" OC studs, and the 24 gauge metal panels are very rigid....no flex
The panels are dipped also, not raw steel........so they are a tad shiny and have a smooth feel
I used OSB for the back 12x15 section of the shop, which I painted with 3 coats of white primer
D
D45
NW INDIANA
Made a rolling, locking caster cart for my old 110v compressor and plumbed in a ball valve for the drain (best thing I've ever done)
D
D45
NW INDIANA
The slate tables?
From a local high school's chemistry lab
They are about 1" thick and EXTREMELY heavy
D
D45
NW INDIANA
This hoist is bad ***
Even came with the owners manual from 1974
Sealed, Oil bath lubricated motor with actual bearings
The 1/4" cable has seen better days, but that's a simple and easy fix
Total weight is only 40 pounds
Lifts 1,200 on a single line
Gear reduction is 533:1
D
D45
NW INDIANA
Trying to think about a beam/trolly/hoist setup for my shop
I found this pic online, and like the idea of running the beam length-wise down the center of the shop, supported across many ceiling joists
Any issues with running the beam this way?
rancherbill
Foothills County, Alberta, Canada
No, but realize when you are the end of the beam your lift capacity is substantially decreased. The end is only supported by just the end fasteners.
It raises my eyebrows for two different reasons. My oldest son would see the I Beam and think he could lift 3-4 tons with it especially seeing the chain hoist. He would not think of de-rating the lift at the end of the beam. My other son, the engineer, would spew facts, figures, dynamic loading, formulas, standards etc. ad nauseaum, and say it was only good for 500-1000 pounds.
D
D45
NW INDIANA
Good point(s) with the end(s) of the beam
I am just not sure I like all the weight being held up by a single ceiling joist
Not like I will be using for 1,000+ pounds anyways
D
D45
NW INDIANA
The shed is coming along, maybe another 3-4 weeks and I can empty on ton of stuff out of my garage
I did find a nice score in Craigslist, two TrippLite Power Strips for $60
They sell for $80 each and will be a nice addition to the outer walls, for power access
PS7224-20 Vertical Power Strip 20A 120V
http://www.tripplite.com/power-strip-24-outlets-15-ft-cord-20a-vertical~PS722420/
▪ 24 outlets
▪ Convenient and safe covered, on/off switch
▪ 20-amp circuit breaker
▪ 15 ft. cord
▪ 72" length
D
D45
NW INDIANA
Here is the link to my 10x12 shed build
http://www.garagejournal.com/forum/showthread.php?t=244568
When it is all done, within the next 2-3 weeks.......I can clear about 1/3 of the junk out of my garage
All the hunting, yard work, lawn care stuff, pool items will be out of the garage and into the shed
Here are some more pics of the attached additional garage, cool idea by the previous owner
This is taken from inside the enclosed patio......this is the door leading down (2 steps) into the additional garage/shop
D
D45
NW INDIANA
Here are some pics from inside the sop, showing the front and back section, both of which have their own insulated garage doors and openers
I like the sliding door feature too
It is a complete disaster!
Main shop:
D
D45
NW INDIANA
The sliding door that separates the garage into two sections
Looking from the main shop area into the smaller area:
Looking from the small area to the door, which leads into the large shop area:
Some pics of the small area, which is also packed full
D
D45
NW INDIANA
Does anyone else hoard scrap wood that is left over from projects and have a hard time throwing it away?
If so, how do you store it, so its out of the way, yet still neat and orderly?
Or.......just chill out and throw it out?
D
D45
NW INDIANA
I painted the wall siding that I installed in the enclosed patio (and the common wall in the garage, and in the garage surrounding the garage door.
Yes, I insulated behind the siding panels
Sherwin Williams was able to scan and color the pre-existing red about perfectly
They also tinted the primer I used
Before and after
DeadSock
Sterling, AK
I used to hoard it. Now I pile it during dry season, whatever didn't get picked from for a year got dumped in spring. Repeat.
D
D45
NW INDIANA
I hope to get a ton done in the garage over the next 3 weeks
The shed will be done next weekend and filled up.........so the garage can be cleaned out!
I am going to build a rack for my two long extension ladders, so they are tucked up high in the corner of the garage. I plan on using 2x4s and running them down the wall, from the rafters and create a box for the ladders to slide into
D
D45
NW INDIANA
I am designing and making a bunch of wall mounted shelving out of 2x4s, for storage tots and long(er) term storage
Would you guys suggest using an framing nailer to speed things up .............or drill and screw the 2x4s?
D
D45
NW INDIANA
My shop is basically wired with white coated Romex
What is the diff between the white coated Romex and the yellow coated Romex?
I would love to redo it with conduit, but that's not cost effect for me
Most of the Romex was ran poorly, across the ceiling beams and all over the place
I would love to redo it this winter, using longer pieced of wire that was hidden ontop of or on the sides of the exposed ceiling boards
Anything I need to know when looking at Romex for ceiling lights?
I assume I need 3 wire, right?
10/3 246' NMD-90 w/Ground
12/3 246' NMD-90 w/Ground
14/3 246' NMD-90 w/Ground
10-3 15' NM Wire with Ground
12-3 15' NM Wire with Ground
D
D45
NW INDIANA
I got sick of walking around and moving 5 ladders, so I built a rack for all of them tonight
Tucked up high on the wall for the two extensions ladders and I added hooks for the 8' and 10'
Much better now........there is also a smaller 4' ladder hanging on the wall, its just hidden
Tomorrow I am going to start hanging cabinets and building more shelves
Self drilling 3" Grip Right screws with T25 Torx head and my impact driver is soooooooooooooooooooooo nice
D
D45
NW INDIANA
I just bought a new 24 circuit, 100 amp rated subpanel and a bunch of 12/2 Romex
Time to shop around for T8 fixtures or T8 ballasts, to replace all my T12 lights
D
D45
NW INDIANA
I am going to make a long storage shelf, running high up on the same wall as the ladder rack
Similar design too, just will be meant for storage totes..........high up on the wall and out of the wall, yet still accessible
The wood hanging from the roof will be 2x4s, while to the horizontal wood will be 2x6s
I bought four 2x6x10 boards, so that I can make two long shelves, evenly spaced out along the wall
I plan on making them 2' wide, so I can buy the precut 2' wide OSB.......I am thinking 1/2" thick. The precut 2' wide OSB will save me so much time not having to cut everything
A 1/2" 2'x4' piece is $4.50
A 3/4" 2'x'4' piece is $6.50
I might go with the 3/4" for strength and not have to worry about sagging, even though it will just get totes with misc junk like camping, painting supplies, etc.....nothing heavy
D
D45
NW INDIANA
I started on the two, 12 foot long sections for the storage shelf
Did not get too far, had to watch the little one
I left about 12" of space between the last shelf and the wall, for a quad outlet
I also spaced the two out about 18" from each other, again, for a quad outlet
I need to get some OSB this week, and find another 2 hours to finish the shelves
Lassen Forge
I left the reflector off one of my 4 bulb 4 ft T5HO to see what would happen, and it lit up the roof of my shop nicely, but I put it back on as I wanted the light where I could use it. IMO it does make a difference, as more of the light ends up down on the bench and floor, rather than lighting up my rafters and steel roof.
I switched from (originally) dim and dingy T-12's to T-8s (because of the T-12 phase out - no regrets there!)... then saw a shop running T5-HO bulbs, and was so impressed I bit the bullet and swapped mine out. It was like going from household lighting to having daylight in my shop. Yeah, they're a little more pricey than T-8s, but it was worth every penny being able to see everything everywhere! The T8's sold on Craigs, and got part of the $$$ back, but if I knew ahead of time, I would have went directly to the T5's and saved the money.
