Jim Caudill
There are a couple of ways to deal with this issue of a large inrush of current. One way is with a knife switch where the ammeter is connected across the switch, and the switch is inline with the battery connection. You leave the switch closed for a bit, and then you open the switch to examine the current draw. You can do much the same thing by having your ammeter setup in the normal way, but you use a decent gage jumper lead to make the initial contact. After everything is stable, then remove the jumper.
I have an old Sears auto analyzer that has a swing blade to carry the larger current and then you open it up to see small currents.
