Hello all – I need some advice, I have worked hard all my life and now the wife is going to let me do up my garage.
I have been sent samples and brochures on the AutoDeck tiles and RaceDeck tiles. I have also been right through this forum reading about the RaceDeck tiles but there is not much on AutoDeck.
The AutoDeck sample I have appears to be stronger than the RaceDeck, it has more lugs than the RaceDeck and these lugs are at least 70% bigger than RaceDeck, plus when you snap them together the AutoDeck tile seems to have a tighter fit.
Also I weighed the tiles and the AutoDeck tile is heaver indicating to me that it would contain more material. Underneath the AutoDeck tile it has more points of connection with the ground which should dissipate more load than the RaceDeck tile.
The AutoDeck tile has a better water channelling system built in allowing your concrete garage to breathe and dry out better.
AutoDeck is USA made and owned just like the RacDeck tile.
I have also noticed that the guy from RaceDeck when posed questions about AutoDeck and others says that RaceDeck is 100% USA made and uses only new material unlike the other companies.
So my question to all is:
Am I missing something here? Is AutoDeck not actually made in the USA? Is AutoDeck not made from new material? Does AutoDeck use fillers in their manufacturing? Disregarding the RaceDeck brochure is AutoDeck not actually as strong? Who makes AutoDeck?
I would appreciate any help as I got excited about the AutoDeck tile when I received the sample and found that while the brochure was indicating a lower rolling load the AutoDeck tile seemed stronger.
Cheers
Cheers
