Automatic centre punch shopping for .
dogdog
was $1.99 ones from HF. or the ones with hammer.
but if I was to choose, I would get that 18C. Starrett stuff are always premium. a manual punch with a ball pin hammer is always the better precision.
Tools4Me
I have a couple Starrett 818's. I prefer the lighter aluminum body of the 818 over their steel bodied models, and being aluminum I don't have to worry about oiling/surface rust from my fingers handling them regularly either. I now have three, all purchased used from garage sales. Instead of selling off one or two of them, I set one for light hit power (plastics, fiberglass, mdf), one for medium (aluminum, brass, copper, thinner sheet metals), and one for hard hits (thicker steel). I grab the one I need so I never have to adjust the punch power for the material.
In the past I have used General No. 77, No. 79, Craftsman 40541, and 40542 center punches and they worked fine too. They are good used vintage options if you are trying to keep the cost down.
Outahere
Idaho
Jlarson
I run a few 18C's but we do heavy fab work, a buddy that does sheet metal uses the AA, if you use the C on gauge metal it's gonna make a pretty good dent.
zmotorsports
Northern Utah
I have an inexpensive import one that I've had for about 15 years or so. It works ok and I have had to touch up the point a few times. I also have a relatively new Starrett 18C that I've been using for the past couple of years now and I freakin' love that thing. There is definitely a quality difference between them.
I generally follow up these spring loaded center punches with a good smack with a center punch and hammer before going to the drill just to give a slightly larger divot for the drill bit to engage with.
scooby074
Nova Scotia
Starrett High power automatic one for me to mark the exact center, Then I follow up with a wider Starrett (square body) hand punch hit with a hammer to make a proper divot.
Steve_P
Yeah, another vote for Starrett. I have a cheap HF and the Starrett's are just so much nicer. Yes, they cost more, but.....
JradM
Alberta
tripplejl
Mainer
The Starrett 's are hard to beat but I am really liking the recently acquired Spring tool set. I got the 3500 psi kit and if I were to do it again I would probably buy the heavier 5000 psi spring tool kit.20220127_185552.jpg20220127_185558.jpg
larry_g
oregon
Me, if I have to locate to layout lines then it is a manual ***** punch followed by a proper center punch. I have a few Starrett spring punches that I will use for coarse work but most times just a center punch and hammer for me.
lg
no neat sig line
tarbellb
Oregon
I was on the same hunt
Ended up with both a Starrett 18C and a very nice Fowler, both worth every penny
I've got a manual punch for marking center, than a couple of Starrett 18A and 18b, bought used, and some Snappy spring punches, depending on where I am working, for making something big enough to hit with the drill.
Hadn't thought about setting the springs differently like Tools4Me said, wise choice
Mgdoug3
KY
I have two 18B Starretts I got in a machinist tool box. I don't know how I did without them now. Both of mine are vintage and one still has the box but both work flawlessly.
Straightgrain
North Texas
I have the Starrett 18A, B, & C, the A & B I picked up at estate sales and the C I purchased new. I use a cheap no-name auto punch on occasions but it's like a toy compared to the Starretts.
txvwnut
Bedford, Texas
I’ve got a Central tools one and wish it hit a little harder. One of these days I’ll get a Starrett so I can compare. I do have a HF one and it won’t make a dent in a coke can.
Rinspeed
NY
I wouldn't buy any of them other than Starrett. Throw a little oil in them once in a while to keep them running smooth.
Steve_P
Starrett does punches (all types) and tap handles really well; these items are worth the $ IMO. I think that's the only Starrett stuff I have except for a 6" metal ruler I inherited
Edit- I have the 18A and C. Sometimes the lighter duty A is what you want- like on sheet metal. IIRC I didn't get the AA after reading the reviews saying it had almost no force
tarbellb
Oregon
My issue wasnt so much with how hard it hit
my cheapo punches would glitch and not reload the pin
I would have to mash the tip, rebuild, etc... very frustrating for what should be a fraction of a sec operation done dozens of times
2ndGearRubber
Pittsburgh
Gonna vote AGAINST starrett. My 18c is, and has been since day 1, garbage. My smaller 18a is good and reliable, but the 18c has almost a 100% failure to strike issue. I've tried cleaning, greases, oils, 100% dry inside, nothing makes it functional. Slow push, fast push, same deal. I can fiddle with it and make it hit once, but then it's right back where it was. It also only functions at the lowest possible tension, anything above that has literally never resulted in function.
IndyGarage
Indy
I use a Starrett - the aluminum body one - used it about 20 times the other day.
A couple years ago I saw a video on an optical center punch. I ended up buying one and it's really cool. I've only had reason to use it a couple times. If you really need to have precision it's a great product.
jonshonda
Wisconsin
I have the Starrett 18C which is ok for really hard materials, but too large imho for wood or softer metals. Don't get me wrong, it works just fine, but I am likely going to buy an 18AA if I ever come across one for a "daily driver".
Rinspeed
NY
just as a FYI all you have to do is loosen the end cap to reduce the spring pressure.
My 18c is, and has been since day 1, garbage. …the 18c has almost a 100% failure to strike issue. I've tried cleaning, greases, oils, 100% dry inside, nothing makes it functional. Slow push, fast push, same deal. I can fiddle with it and make it hit once, but then it's right back where it was. It also only functions at the lowest possible tension, anything above that has literally never resulted in function.
One of my used ones was like that. Found the patent, figured out what the trip mechanism was, and cleaned that up specifically, and it’s been fine since. Unfortunately, I forget what the trick was, but it wasn’t obvious til I looked at the patent. HTH
Luciferi
I bought the 18c and works great but is little hard to push sometimes if in an awkward location. It has slid out on me when trying to press down on more than one occasion. It seems that it is never where I last adjusted it and I forget to check before using.
I got an 18a and it is much easier to push down on. I have only used the 18a a few times so far but I don’t think 18c will need to be used very much anymore.
