Average joe's garage(but my own)
My new semi-detached is almost done.
I'm getting my keys in about 2 weeks, so I'll be able to start my single garage build-up really soon. I'll keep you guys posted on what gets done.
Garage size is : 10X20.
Original ceiling height was supposed to be 8' but I talked the contractor into making it 10' (ok, ok, my wallet talked the contractor into making it 10' high).
In order to maximize the space as much as possible, the rear wall will be loaded as you can see in the image.
btw, there might be some odd visual effects on the back wall. That's normal. I was originaly standing in the middle of the garage door in that picutre. I had to photoshop my-self out of there.
There will be a computer monitor mounted between the studs inside the rear wall where the workbench is and the monitor will be covered with a plexiglass so it doesn't get damaged by flying tools (not that it ever happens
). I won't need to run inside the house to get the web info I need anymore. That alone will be a great time saver.
