Burt Shaver
- Joined
- Dec 7, 2023
- Messages
- 1,170
trying to change a brake line on a 09 Elantra. I purchased this Bubble Flaring tool brand Performance Tool from Rock Auto. I am having much difficulty using it, I will just state some details in poker form. I purchased 25’ of NiCop 3/16 line, picked up the line and tool today. Tried about 10 test flares. At first the bottom of the bubble was all deformed, I think I got that worked out, I had to much brake line past the die block, 3.7 mm seems to work best for me which is just a hair over 1/8” . Also found that some lubrication with WD-40 helped the flare turn out better. So I had done some research online before buying this tool and it was my understanding that the bottom portion of a bubble flare is supposed to be at a 90 degree angle but this tool makes the bottom at a 45 degree angle? The top part of my flare I’m happy with, it’s the bottom that I’m worried about. Even the best flare I have made has imperfections from the rolling of the tool, the 2 sides of the die block are beveled and I can see this bevel in the bottom part of my flare. How perfect does the bottom part of the flare need to be? Also when I tighten the die block into the brake line the two sides of the die block are at slightly different elevations, maybe a 16th of an inch roughly, there’s a lot of play in the screws to tighten it. I will post some more picture that I have taken, I don’t expect to be making many flares in my lifetime so I was hoping to get away with using this chinesium tool for 23.88.
