band saw help please
edbrown
iowa
Hi i recently bought this older montgomery wards horizontal/vertical band saw off a guy for $40.i dont know anything about it except there is no model number on it anywhere that i can find and it needs a new blade.Can someone tell what model it is or maybe where i could get a manual and maybe where i could get a blade.i dont have an exact pic of it but its exactly like this one here that i found online.Thank you very much
zkling
Can you take a close up pic of the name plate? It looks like a standard 4x6 horizontal/vertical off shore job. Should be ~ a 64.5" x 0.5" blade.
E
edbrown
iowa
mine doesnt have a name plate on it,these pics are what i found online.The only name i see on mine is on the motor its a power kraft 1/2 horse motor.Do you need a pic of that?.i guess since it says power kraft its a wards right?.thanks
rsanter
visalia ca
You have a blade, right?
Take that blade down to a shop that makes the blades. A saw sharpening place generally and they will make them for you.
Generally better quality than a lot of the pre made blades
Bob
E
edbrown
iowa
yes it has a blade on it,thank you for the tip and i like your sig by the way lol
gungatim
west mich
you sure it's not a HF/China/Taiwan job with the motor replaced with an old PowerKraft? what color is the saw?
thebeekeeper1
Illinois
If you have a blade I know Fastenall will make a new one for the same price as a pre-made. They run about $40 for bi-metal. :)
E
edbrown
iowa
thanks,we have a fastenal in carroll which is about 17 miles from me ill check there
rsanter
visalia ca
Also, those type of saws are very common in a number of different brands.
Take the original blade, measure lenth with a string, or roll it on a tame measure to get the lenth and you can do some new searching for a replacement.
If you buy pre made replacements then get a name brand blade.
If you to to HF and get a blade you will want to kick yourself later
Bob
Just because the Motor is MW does not mean the saw is. Post pics of YOUR saw, "Just like" may mean nothing... (Heck you may have bought my old saw from the guy I sold it to, I think I stuck a MW motor on it way back....)
E
edbrown
iowa
Here's my actual saw..if it works
zkling
Montgomery ward did make horizontal bandsaws back in the day. I don't remember the COO, I want to say 70's-80's Taiwan. Pretty sure it is a standard 4x6 H/V job.
Yep, pretty typical Taiwan re-brand. I se a tag of some sort on the gearbox cover, what's that say?
Most of these used a 64-1/2" X 1/2" blade IIR but measure yours and take a peak at where it is adjusting. if tight, you might want a tad longer, if barely getting tight then maybe a bit shorter.
That should clean up fine, and there are "tuneup" threads all over the internet for these things. They cut decently with decent blades and adjusted properly. $40 is a good deal.
ps: a good mod for those is to make up a catch tray/drawer and hang it under the main base ( a couple of sheet metal or aluminum angles screwed to the legs works) and it will catch 90% of the shavings, saving a LOT of cleanup...
E
edbrown
iowa
the sticker says "caution read owners manual before operating"..i like the catch tray idea..i'll measure the blade and find out what it measures for sure thank you all very much you have been a big help...its appreciated
gungatim
west mich
in your 2nd pic, the top wheel mount area where the chrome bolts are? you usually have to shim under there to get your wheels coplanar if you have trouble keeping the blade on and tracking. I think I have .030 shims behind my "Buffalo Machinery" version of this saw.
nomadskidoo
iowa
Identicial to my "delta" 4"x6" verticial (1985 purchase) and no model # i could find but will find the owers manual built to deltas spec(taiwon built)
finn
The UP, God's country
Looks a lot like my Wilton, probably from the same factory.
Mine takes a 67 1/2 inch blade, which is somewhat difficult to source. I think Grainger's discontinued it, so I'll have to have one custom made next time.
The 64 1/2" blade is more readily available (but won't fit).
E
edbrown
iowa
im not sure what kind it is for sure but its kinda cool especially for 40 bucks lol
sasquatch12
Heck for $40.00 you can't go wrong. If the worm drive in the gear box isn't worn out, everything else on those saws can be easily repaired. Wouldn't hurt to open the cover on the gear box and change the gear oil, changed mine to standard #90 gear lube.
Great design of saws, sold by the hundreds of thousands, one of the best shop labour saving buys going!
I have an old Taiwan built model -the tags were long ago knocked off, they just came with very flimsy stands.
Check the bushing in the adjustment drive wheel for wear, if worn, again easily replaced.
tedsters
$40 is a pretty good deal if you have a REID TOOLaround you it is the best place to buy a blade they will weld you one up while you wait for it cheap to good premium blade
E
edbrown
iowa
no gus1962,i havnt been out in the garage lately its like 13 degrees here and no heat out there.going to order a blade and hopefully it'll warm up a little soon lol..
