Yes,about 10-1.....metal speeds are gonna be 3-400 FPM,give or take,and it is critical to quality of cut and blade life.Blade cooling is done with liquid coolants for the most part.
Wood speeds would be 10X that...@ 3-4000 FPM.On the wood side,its not "quite" as critical as metal speeds....UNTIL,you get to resawing and/or exotic woods.But for general wood sawing....the speeds are a little more tolerant.
Chip evac starts to be an issue on wood though.Short of full-on...bigazz "mills",liquid coolants for blades are generally more hassle than they're worth.But a LOT can be done with air.It not only cools the blade but can be a make or break it(literally) when resawing.....Well its also used on highly abrasive exotic woods.We have some here that are about like runnin a pce of Aluminum through through your wood BS.Heck,a species as benign as Purpleheart will peel a sharp blades edge as fast as you want?And yes,we sharpen/set our own.Introduce some serious air,directly into cut and its almost tolerable.
