bobj49f2
I have an older horizontal band saw that just has a wall light switch in a box that turns it on and off mounted next to the motor. You have to reach over the saw to turn it on and off. The saw runs as long as the switch is in the "ON" position. I want to mount a switch on the saw so it turns the saw off after it reaches the end of the cut. I've seen saws with a "ON/OFF" switch mounted in area where a bolt or some other studs comes down and pushes the "Stop" switch which in pops the "ON" button up so you you have to manually push the "ON" button in to turn the saw on again.
I've been searching the internet but haven't found a counteracting "ON/OFF" switch. Anyone knows where I can get one?
