Bandsaw question
davidlee
Pensacola, Fl
I was given a Craftsman band saw which I never use. Can it be converted to a metal cutting saw by changing the blade or do they run at different speeds?
csp
Franktown, CO
Metal bandsaws run at slower speeds than wood ones do.
There are webpages documenting how people have slowed them down.
K13
St. Albert, AB Canada
Different speeds metal cutting saws run way slower. Guys do convert them by setting up pully speed reduction configurations.
Cyberbear
California
Wood cutting band saws are way too fast for cutting metals, although I've used my 14" wood cutting band saw to cut aluminum but is still hard on the blade. You might try adapting the proper size pulleys for metal or find a suitable two speed motor that will work for your needs.
zoomzoomjeff
Des Moines, IA area
What type of metal? If it's paper thin sheeting like roof sheeting or something, and the saw was given to you, and you don't have long-term plans for it, then sure. Find a very fine tooth blade and go at it. Just don't expect long blade life. But for something thicker, you're going to want to slow the blade way down and use an appropriate toothed blade, with the closest to optimal speed for that material you're cutting.
magrahamkp08
Central Virginia
You may be able to slow the speed down with a VFD
I too have wondered about this. I too have wood bandsaw, that i would like to convert to a metal bandsaw. I have a VFD, but its currently hooked ot my lathe. If there ever comes a time where i need the metal bandsaw, ill wire into my VFD and report back.
matt_i
The basic conundrum is this: Wood 3000 sfm, steel, 100 sfm. So that's a 30:1 reduction in speed from the motor. The problem with a VFD is the motor would run roughly at 2Hz (instead of 60Hz normal) and while it would run it would have nearly zero torque. A single belt reduction won't work (1" dia pulley driving a 30" pulley is unsuitable). So it becomes a job to setup a ganged or multiplied reduction of something more reasonable like 5:1 x 6:1. There are a few more subtleties but that's the crux. A VFD will require a 3 phase motor, although most can run on single phase input power.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Hi.
I converted a good quality bandsaw from wood to metal, and got the correct blades. Used a two stage gear reducer. Looked like a success.
After a while the blade was hard to track. This was caused my metal chips having embedded themselves into the rubber coating on the wheels.( around 750 mm diameter.
Had to strip the rubber and have them rerubbered.
So, my saw was not suitable, now back to wood only.
Ola
EricP
Alabama
If the bandsaw has a single phase motor you won't be able to use a VFD. The motor will slow down and the centrifugal switch will close and stay closed blowing your start capacitor.
kf4zht
Calhoun, GA
It's doable with some jack shafts and pulleys. Good thing is there is usually plenty of room under the saw to move the motor around
Also check the motor RPMs, lots of things come with 3450RPM motors, swapping to a 1725RPM motor gives you an instant reduction.
zkling
Ah good, this hasn't come up for a week or so.
Did you do a search? I guess that is a rhetorical question at this point.
justanengineer
Motor City
Converting a bandsaw from metal to wood really depends on what youre using it for. I'm pretty familiar with the limitations as I've helped a number of model and car club members with these "conversions." Benchtop saws really arent rigid enough for cutting bar stock, so forget about most anything thicker than steel plate. The guides and tires also generally **** and will cause major issues in thicker metals. I had a 14" Delta with the factory gearbox to do wood and metals and while better than nothing frankly it sucked compared to a decent industrial saw. It didnt properly support the blade well enough to keep the blade in the cut so it was constantly half cutting/half rubbing, wearing out blades and me. Yes, a 16-24" saw is another few hundred $$$ over a cheapie homeowner saw (~$500 vs ~$300 locally), but a lot of folks waste that much converting a saw and still end up with something that ***** IMHO.
nadogail
Coronado, CA
Short answer is yes, I occasionally saw aluminum on my Craftsman with no problem. I wipe the swarth off the tires when done.
Having said that, my Craftsman is not a DoAll, and will never replace one.
yaidunno
WI
Comparing it to an industrial saw is about as apples to oranges as it can get. I have no troubles cutting 1/2" steel plate on mine with a 1/2" Starrett blade. There is no blade wandering, rubbing, or tracking issues to speak of. Long cuts in anything thicker than 1/2", I'm having it laser cut.
I paid $400 for my Delta. A decent DoAll will fetch $900-1500 for a smaller one.
