Barn/Workshop Design Concept
tealetm
NY
Hey everybody, hoping to get some feedback for my barn/workshop that I'm in the midst of designing. I'm located in Upstate NY.
Primary use would be a hobby woodshop and some storage. Possibly the occasional quick car project but it would mainly be set up for a woodshop as I already have a two bay garage for vehicles. I currently have an architect working on some designs for separate porches on my house so he threw these plans together for me for the barn. I'll eventually insulate it. The drawings show it tall, I am debating on a loft. We're not settled on the siding shown in the drawings, we'd like it to look more of a barn than a garage and I'm trying to stay away from garage style doors. The overhang is mainly for storing an 18' bowrider boat- I'm not sure if we will enclose that or keep it open as shown but we will probably have that stone versus a slab.
Once we get the idea down on paper I'm going to price out construction, pole barn vs. stick frame so while these are obviously drawn with full foundations and stick built, I may switch to a pole building. Most of the work will be self performed or done with some help.
I have to apply for two variances with the town, so I'd like to firm up the plans as tightly as possible before the paperwork starts rolling (the town is a little strict on buildings so hopefully I'll be able to do the building). The variances are for: (1) accessory building taller than 15' and (2) an accessory building located between the front of the house and the road.
Just looking for some feedback at this point as well as any other things to consider. Thanks!elevations.PNGfloor plan.PNG
billconner
Thousand Islands NYS
I can't tell if trusses or rafters. And I guess I would question foundation details. Why framed floor over slab? Why footer drain with no basement? Why not shallow frost protected foundation? To there's nothing wrong with details except costly IMHO.
ZRX61
Solar Blight Valley, SoCal
The *standard size* for a car project is three bays: One for the vehicle, one for all the stuff you take off & the stuff you bought to go on it & the third for actually "doing stuff with the stuff" before it goes on the vehicle.
But I guess that depends on your definition of a "quick car project"
T
tealetm
NY
Not sure where you see a framed floor over the slab- those lines are dimension lines if we’re looking at the same thing.
He’s thinking scissor trusses for the moment but hasn’t gotten that far.
Frost foundations here are 48” and we can’t do thickened slabs for buildings of this size (unfortunately).
footing drain generally helps with frost issues.
the size is limited to what is shown for site reasons (and cost).
thanks for the input
matt_i
Make sure you have a plan to exclude birds from nesting under your overhang. They gravitate towards that and your boat will be full of you-know-what.
Those Y-shaped post supports seem inviting and any rafter or truss cavity under the roof are also prime spots.
Jeff Ivers
Oklahoma
Can't read any of the dimensions on the provided diagram, but based on the height of the door, the building appears to be 12 to 14 feet to the eave. Unless you are planning for a lift, why have the extra height for a wood shop? That is a lot more volume to heat and cool.
