coalminer16
I spray foamed the shop and thanks to this forum I was convinced to finish the walls to help protect the spray foam from sparks and uv light damage. I got a GREAT deal on some fire bloc osb board that has the same rating as sheet rock but much more durable and I am finishing the walls with that and white oil based primer. I would like to be able to weld, grind and possibly once in a while wash items in the shop. I have the fire bloc osb off the ground a fraction so it would sit in the water and draw it up since the small shop isn't sloped at all as it never had drains.
To the point what would be good for the base boards that wouldn't be wood so it doesn't rot and doesn't break the bank? I have a 30x40 and 60x72 shop I am doing this too. I don't want sparks from welding to role through the gap and slowly start a fire so i want to close the gap without having wood on the ground.
Picture of what I am doing
