I know, I know. It's not a garage. But I just found this site last week and its quickly becoming my favorite place to browse. With all the ingenuity I've seen on this site I figured that has to be some intelligent individuals with some good answers.
My basement is of the floating slab type, cinder block wall, and originally had the standard 1" gap between floor and wall. Once upon a time someone decided to fill this gap in, but did not bring it up above the floors surface all the way around. Normally this wouldn't be a big deal but I have A LOT of ground water considering I live across the street from a river. I have a sump pump in my basement that pumps out probably 150 feet in the opposite direction of the river into a dry well. The sump works great, as does the dry well. My problem is the water accumulating everywhere BUT the crock. I have water seeping through the floor in random spots, puddling up by the walls where the slab gap was filled in, and I even have water accumulating in the corner where the sump is no more than 2 feet away.
Normally I'd say this might be easy to correct by doing a french drain around the house, grading, etc... My problem is that this sump can run year round, the water exists year ground, and the ground water is always present. My yard isn't "soggy" but in the summer time the soil never dries. It's great for growing grass. Not so great for keeping the dogs paws clean
I snapped some photos and am hoping someone has some suggestions? I don't believe drylok will solve the issue. After all the people selling the house claimed the basement had NO water issues after drylokking the basement numerous times, and here we are now! The only solution I've come up with so far is cutting up sections of the floor wide enough to run corrugated plastic back to the crock. The house was built in the 50's and I suspect the existing drainage coming back into the crock could be plugged.
I'm a do-it-yourselfer so whatever the solution may be I'd prefer to do it rather than pay someone.
Thanks for reading guys,
Shawn
Shawn
