And with that list you have more stuff than the shop I work at. Well beyond basic but who cares,
Its your dream, make it as big as the good wife allows.
Remember that I only have the items listed in bold black at the end of the list.
But I am now adding some more to the want list.
Latest list:
Potential tool list:
Next on the list:
Work light LED
Dental picks
Sockets handle trays, deep metric to 27 shallow too.
Electrical Terminal Kit and Crimper
LED 12 volt for testing coil on plug, etc. ($3 or so at electronic supply house
Scanner wide data logging Actron CP9135?
Cutoff tool
Snap ring pliers astro 6 piece
Mapp gas - CL
External retaining ring pliers Matco
Tap and die need good sets SAE and metric HF?
Irwin damaged fastener tool set
Tweezers
Impact screwdriver HF?
Wrenches long box end metric
Wrenches offset metric
Shallow sockets
3/8 and 1/2" wobble impact extensions
Thread restoration kit Craftsman
Hex sockets ball end long SAE and metric HF
Hex sockets impact SAE and metric HF
Star sockets HF
Universal joint 3 piece impact HF
Better organization for wrenches
SAE everything...
Factory service manual 2002 Astro Van
For Service Cart:
Mount for nitrile gloves
Mount for paper towels
Mount for
Shelf
Side cabinet?
Electrical outlet
Air hose rack and fitting
Working on better storage for service cart. Took numerous things out of packaging to save space.
Would like:
O2 sensor and oil sender socket set HF
18 piece brake caliper set HF
Bearing puller set small and large HF
Fuel injection pressure test kit HF
Axle nut socket set HF
Lug nut socket set HF
Silver and Deming drills HF
HVLP spray gun HF
Helping hands HF
9 mil nitrile gloves HF
Small MIG welder
Air chisel
Spring compressors - Would like center one
Interior body panel tools -
Have HF plastic - couple more HF
Short and long wobble extensions -
Have some
Deep sockets -
Have some
Oil Filter Wrench (assortment of strap and cap types) -
Have some
Extensions locking and 3/8 -
Have some
Special pliers cable cutters -
Have some
Not needed yet:
Rear caliper cube - Not needed
Cordless impact - Not needed
Offset wrenches box end metric
Quick disconnect tools
Axle nut socket set powerbuilt O'Reillys
Body panel pliers HF
45 degree pin puller
Leslie blind seal puller
CV joint boot band installation tool
Air chucks for pressure testing cylinders
Compression tester
Fuel pressure gauge
Vacuum gauge
Chain Wrench
Roofers magnet -
Use HF magnet bar
Stud remover
AC tools
Disconnect tools
Hex shaped connector removal tool
2nd cart
Hose cutting tool -
Use utility knife
Hose disconnect tools HF
Really long 90 degree pliers
Big channellocks
Curved needlenose
Slide hammer
wrenched chopped wrenches S wrenches
Oil sending unit socket
Eastwood pro flaring tool set -
use small set
Specialty wrenches
Brass rubber mallet HF -
Have separate ones
Cable actuated hose clamp pliers
Bolt puller set 40pc HF
Brake caliper tool set
MAC flare set
Balance puller
Block tester
Noid light HF
HAVE:
Long reach pliers 20 and 45 degree offset HF
Long reach hose grip pliers HF
Long reach pliers HF
Left hand drill bits HF
Impact swivel sockets metric HF
E reverse Torx sockets metric
Step drills large set of 2 HF
Wrenches long combination metric HF
Shallow impact sockets metric and SAE 3/8 and 1/2
Metric Impact Sockets HF
SAE impact sockets HF
Flex sockets
Pry bars Craftsman
Pry bars HF
Screwdrivers misc, and HF
Mirror & magnet tools extendable
Flashlights misc
Small screwdrivers misc
Brush - Have
Electrical tape
Teflon tape
Pliers misc
Paper towels
Nitrile gloves 7 HF
Long 90 degree pliers HF
Torx or star sockets
Allen sockets metric and SAE
Blow mold 1/4" socket and ratchet set Gearwrench
Office paper clips for cam belts
Crowsfoot wrenches metric
Breaker bar HF 3/8 1/2
Torque wrench HF 3 sizes
1/2" Impact extensions HF
Impact extension size converters HF
3/8" Extensions locking and regular
Air ratchet - Husky
4# hand sledge
Dead blow hammer 4# HF
Side cutters
Ball joint set HF
Extended ball joint set HF
Magnetic parts dishes HF
Mity vac HF
Pitman arm puller HF - Get puller kit?
Ox/ac set
Coolant tester
Calipers
Micrometer
Rivets
Rivet gun big hand
Multi-meter Milwaukee and HF
Test light incandescent HF
Drum brake tools
Jack HF and Arcan Alum.
Jack stands HF 3 and 6 ton
Wheel chock
Impact gun HF Earthquake 1/2"
Safety glasses
Pancake air compressor - Porter Cable
Alignment punches
Chisels - Have a selection
Hacksaw - Have a couple
Vise - Have a few
Picks HF small set - Get better?
Grease gun - Learn to use
Flaring tool set small - Good for now for brake lines
Vise grips - Have a few
Channel locks
Supplies:
Super lube HF
Brake cleaner
Kroil
PB blaster
Wheel bearing grease
Brake lube
Anti-seize
Shop towels
Paper towels
Shop Equipment:
Grinders with wire wheels and stones and buffs
Drill press
Bridgeport
Lathe
Horiz. band saw
Parts washer
Arbor press Grenard
Hyd. H press HF
Hose reel
Disc sander
Belt sander
Anvil
Other:
Rolling stool HF
Creeper HF
Dead blow hammer HF
Rubber mallet
Brass hammer
Drill bits HF
First aid kit
Fire extinguisher
1/4" insert bit ratchet
Universal joint for sockets
Files
Gasket scraper
Battery terminal cleaner
Wire Stripper
Feeler Gauges/thickness shims
Dial or Electronic caliper HF
Micrometer
Spark Plug Gap gauge
Timing light
Battery charger
Oil drain containers
Engine cart
AC DC stick welder HF
AC DC welder Lincoln
Bill
