Battery post studs? Good deep cycle brands?
Innovate1
Illinois near St. Louis, Missouri
Need to replace the deep cycle battery in my RV. I see the existing battery has studs that appear to be a threaded rod that then gets a nut. I saw that they had an allen socket so thought it would be good to keep the studs in case I needed them with the new battery. I tried to get them out but with lots of torque it looked like it was going to strip out the allen socket with more torque. Is this something I need to get out or do most batteries come with the studs already there? Looks like the Duracell battery I am looking at has studs so perhaps I don't need to worry about it.
https://www.samsclub.com/p/duracell...nd-rv-battery-group-size-31dtmagm/prod3590232
Also wondering about good brands. The one I am looking at only has 18 month warranty and I see some bad reviews of it failing. Could be due to how the battery was treated - run until dead, etc - but still concerning.
danho
SW Oregon
Not sure about the studs or specific application, but I have always had good luck with Trojan batteries for my RV.
Leaflessshadetree
Don't ask.
Many deep cycle batteries come with studs.
If you want to remove them from your old battery, double nut them. You can apply more torque than with an allen wrench.
nadogail
Coronado, CA
In my experience, I have found the larger diameter post to be Positive and the Smaller one Negative, the threaded connections on my Chevrolet van are tapped for 3/8-16.
theoldwizard1
SE MI
Trojan deep cycle batteries are EXCELLENT ! If you have the room 2 - 6V golf cart batteries work well. They sell battery top post to stud adapters for only a few dollars.
liFePO4 are getting cheaper every day. The biggest issue is they require a different battery charger in order to get to 100% "state of charge".
