Bed frame angle, what's it made of?
ching0n
I figured it was mild steel since 'who would go through the trouble of rolling angle for bed frames?'. Abrasive disc had a harder time than I expected and it cracked on me when I used flux core on it.
C
ching0n
All over the machining hobby forums you are warned away from bed frame material. It is a mix of scrap metals that are very hard and not machinable or weldable.
I saw the warnings from the google but wondered if the opposite could be true? Meaning it's a special blend hardened/spec'd for stiffness to hold two adults doing the biz? Imagine angle iron made of spring steel and expecting it to behave like mild IOW, it'd be easy to chuck it up as '**** steel' too no?
rlitman
Long Island
It's s**** made with medium to high carbon. Heat treats into a lightweight but stiff frame, but welds into a brittle nightmare. Same **** as non-weldable rebar. "Special blend" of old school bus frames one day and ship parts another, but unlikely to include anything as quality as railroad track.
rlitman
Long Island
I weld it all the time, NOTHING structural. Drilling can be difficult.
It's usually tempered out of the factory, so drilling works best if you start with a sharp bit and use heavy force to keep it cutting (lube helps), but only before welding. Once you let it heat up (by welding, or just friction with the drill bit), get the abrasives out.
I also keep pieces of old bed frames around for random stuff, but yeah, nothing structural.
C
ching0n
Notice any different between the angle used? I picked two widths from the scrap yard, 1.25 and 1.5". The 1.25" behaved just like when I welded a scrap transmission flex plate many many yrs ago.
pancholasvegas
It's all trash. Like everyone else said, it's a crockpot of whatever was melted that day. That being said, like others, I do keep it around for non-structural stuff that needs built.
rancherbill
Foothills County, Alberta, Canada
That is misleading.
It is a specific alloy for bed manufacturing. The steel has to flex, bla bla bla a whole list of characteristics. It is made to a specific formula - bed manufacturer do not want failures while customers are in a moment of passion. It is not made up of whatever was at the scrap yard that day.
It is hard, it is weldable if you have the right temp and filler. It is more difficult for hobby welders.
Firebrick43
West central Indiana
That is misleading.
So where can one see this "Bed frame" alloy's specific formula?
C
ching0n
I stumbled onto a hobart forum thread quoting an NJ manufacturer singing its praises w/properties and manufacturing method. Alas, NJ steel mill phased out that product and pulled the docs.
C
ching0n
That is misleading.
I think most people have a misunderstanding of modern steel manufacturing. A whole lot (most?) steel starts off as scrap (be it bed frames or tool steel) and you've got your metallurgist tweaking the batch formula for its specific needs.
That's not to say you don't have some backyard smelters in (pick deregulated 3rd world country) just rolling out **** and exporting products manufactured by the locals either.
Debcrow
New Mexico
It is consistently hard. It can be drilled with a good sharp bit.
I have welded it with no problems after getting proper settings. It is OK for some projects, but In do not use it for anything structural/critical.
If you think it is going to be a problem, bolt it and weld it.
WillyBoy
Genesee valley area of New York state
Also, if you have a portable bandsaw and you want all the teeth removed from the blade, try cutting a piece of this stuff.
It's way easier and less costly to cut with a disc in an angle grinder. I've used pieces of it in a variety of small projects using a Miller 211 MIG.
alfadan
Augusta, ks
I think it was Dirt Jobs where he was in a steel plant melting down scrap. They took a sample to send to the chemist(?) and they told them what needed to be added.
They threw in bags of manganese and other elements. Pretty cool stuff....well hot stuff!
C
ching0n
There was a lot of steel processing talk when I took material science ages ago & it's just like you say. It's like your mother's recipe & it all starts w/the same chicken broth (generally speaking). That Jersey operation though, looks like they recycle railroads by heating the steel to cherry temp and then splicing and dicing the shapes of the finished product. Pretty 'cool' stuff as you say.
I found fence stakes to behave the same when trying to weld them..... ie not good.
that JJ operation that splits railroads also makes fence stakes it looks like.
the 30$ HF mini chop saw struggled w/o a doubt. I should've busted out the plasma cutter but really wanted to pick this cute thing. It's a mixed bag, I like the compactness of it but whoever decided to make the hinge/housing out of plastic deserves to be tried in a stadium like China does.
Get this lady in charge of testing:
MovingAlong
Have always heard that bed frames referred to as the bologna/sausage of the metal world...
Have cut & welded many projects from them: brackets, shelve supports, table frame for wood insets, etc. Nothing you'd need to count on.
Hey, free metal is free metal. :dunno:
C
ching0n
I like using bedframes 'cause they're free, but they can be difficult to work with. I'm not exactly sure what "structural" means in the context of hobbyist welding at home. I guess I wouldn't build a truck frame out of bed frames, but I'll build shelves, etc... whatever out of it.
structural is usually meant to refer to something carrying a load, "critical", where life or limb can be on the line, "decorative" is something you put in a flower pot or on a shelf. I would consider a bed frame, a hanging shelf or a welding cart 'structural', not necessarily 'critical'; though a falling paint can can still kill someone. It would be nice to know how to weld it successfully w/o it quench cracking (pre-heat/anneal?). Found a tip on drilling it:
cowades206
Interesting experiences here. I'll add mine. My first bed rail project, the metal was strong and welded great. Thought I was on to something. I've done a number of projects with bed rails since with results ranging from great to terrible. Some has been so hard, hack saw blades wouldn't cut it and had to use the angle grinder. Some has been so weak I had to scrap it and buy steel. My experience is spread over 30+ years. I didn't know the age or origin of any of the rails.
Sure been a **** shoot, but sometimes I won.
As MovingALong said: "free metal is free metal" and sometimes it has been worth every penny.
Not surprised there are a lot off opinions about this.
Good luck.
cannuck
Rural SK
Wow: flashback time. I haven't been much involved in physmet for 49 years, but if my fading memory serves at all rail is about 70 points C but 100 Mn. The carbon means it is both heat treatable and hard but the Manganese is there for it to constantly work harden from use. It is the Mn that will make it a ***** to get a decent weld (note: most railroad track is welded today, so a *****, not an impossible one). JSS is a fantastic example of how steel can so effectively be recycled (what they do far more processing than could be called re-use or re-purpose).
Jim greengo
Behind my house
Really high grade stuff,have you ever tried drilling a hole in it?
ObnoxiousFumes
Southwest Sask
He distinctly said “sawzaw” TWICE, I don’t think he is to be trusted... 😂
gearhead1
NC
What’s it made of? Short answer: It depends. It depends on who made the bed rail, and out of what material. Not being a smart a$$, let me explain.
I’ve had some that was easy to drill, some that was not easy to drill. Most of what I’ve scrounged could be drilled, I’ve had only a couple frames over the years that couldn’t. Some of it is in fact made from old railroad rail.
If you look at the link chign0n posted, the rail road rail yield strength JS Steel tested is 67,000 psi. A36, which is the spec for a lot (not all, but very common) structural steel. It has a yield strength of 36,000 psi minimum. I read years ago, that a lot of it is near 40,000 psi. The rail road track steel is almost double the strength of common A36.
Now let’s talk hardness. Looks like rail hardness ranges from 280 to 420 HB. (HB means Brinell scale). A36, one common structural steel has hardness of 119 to 162 HB. Railroad low end grade is almost double the high range of A36 structural steel.
So…..the bed frame made from railroad rail is almost twice as strong AND twice as hard as A36 common structural steel.
Here’s what I do:
I take any of it I can get for free then the first thing I do is try to drill a hole with a common drill bit that is easy to replace like 1/8”. If I can drill it easy, I keep it. If not, I keep it separated and scrap it.
I‘ve used more bedframe than I’ve scrapped over the years. 😉
gearhead
C
ching0n
Here’s what I do:
gearhead
I think I'm going to get me a hardness file kit to pack along w/my fish scale and tape measure any time I go to the scrap yard from now on.
