Bellaire Air Compressor
Tom631
Mt. Pleasant, Pa.
Im going to look at a Bellaire air compressor 318VL for sale. I read the specs. on it,and was wondering if anyone has one or has an opinion on it.
Pros & Cons
6PTsocket
Pros & Cons
Belaire is a brand of IMC, that makes the Harbor Freight 5hp/60 gal. and others for some of the big box stores. I know that doesn't help you much but I thought I would mention it.
T
Tom631
Mt. Pleasant, Pa.
Thanks for the input. I ended getting it for $650. It is for home use , to do a little sandblasting, try my luck at spraying painting etc.
T
Tom631
Mt. Pleasant, Pa.
Here is the pump that's on it.
Description
T39 COMPRESSOR PUMP ABAC AMERICAN IMC BELAIRE
PART#: T39 The T39 compressor pump has cast iron cylinders, stainless steel valves, oversized ball bearings, triple pass pump and mounted after cooler. The T39 replaced the T35. Same fittings and bolt pattern. Only difference is crank and connecting rods. Mounting holes front to side holes front to back are 6.57″ Side to side holes = 9.25″
Specifications:
Cylinder Cast Iron
Bore: 4.13 x 2.05 960 RPM @ 5.0 HP
STroke 2.95 1360 RPM @ 5.0 HP
Min. RPM: 700 18.50 ACFM @ 100 psi (5 HP)
Max. RPM: 1400 25.5 ACFM @ 100 psi (7.5 HP)
Maximum Pressure: 175 psi
15.00″ Flywheel
2 A Section Belt
Oil Cap.: 1.25 Quarts
Lelandwelds
Central Texas
Description
Specifications:
Cylinder Cast Iron
15.00″ Flywheel
2 A Section Belt
Did you mean 7.5 hp for the red line? So, this is the Italian and not the Brazilian pump? Aluminum rods? Isn't the same pump used on CP, Samborn, and others?
I have never seen one in person. That's a good price.
6PTsocket
That is some deal, about a third of the going price. Any more where that came from? LOL!!
T
Tom631
Mt. Pleasant, Pa.
It was manufactured in 2010, used for about 3 years to run cigarette making machines. about 10 to 12 hrs a day. Oil changed regularly.
T
Tom631
Mt. Pleasant, Pa.
Its made by Chicago Pneumatic . Same one as this,different color and labels. Chicago Pneumatic 7.5-HP 80-Gallon Two-Stage Air Compressor.
