Tom631
Im going to look at a Bellaire air compressor 318VL for sale. I read the specs. on it,and was wondering if anyone has one or has an opinion on it.
Pros & Cons
Pros & Cons
Belaire is a brand of IMC, that makes the Harbor Freight 5hp/60 gal. and others for some of the big box stores. I know that doesn't help you much but I thought I would mention it.Im going to look at a Bellaire air compressor 318VL for sale. I read the specs. on it,and was wondering if anyone has one or has an opinion on it.
Pros & Cons
Here is the pump that's on it.
Description
T39 COMPRESSOR PUMP ABAC AMERICAN IMC BELAIRE
PART#: T39 The T39 compressor pump has cast iron cylinders, stainless steel valves, oversized ball bearings, triple pass pump and mounted after cooler. The T39 replaced the T35. Same fittings and bolt pattern. Only difference is crank and connecting rods. Mounting holes front to side holes front to back are 6.57″ Side to side holes = 9.25″
Specifications:
Cylinder Cast Iron
Bore: 4.13 x 2.05 960 RPM @ 5.0 HP
STroke 2.95 1360 RPM @ 5.0 HP
Min. RPM: 700 18.50 ACFM @ 100 psi (5 HP)
Max. RPM: 1400 25.5 ACFM @ 100 psi (7.5 HP)
Maximum Pressure: 175 psi
15.00″ Flywheel
2 A Section Belt
Oil Cap.: 1.25 Quarts
That is some deal, about a third of the going price. Any more where that came from? LOL!!Thanks for the input. I ended getting it for $650. It is for home use , to do a little sandblasting, try my luck at spraying painting etc.
