Belt or orbital sander
barnettnce
Birmingham
While I have a larger job I use my belt sander, maximum of the rest of the time I use my random orbital sander. I very rarely use my quarter-sheet sander, but there are times when it fits better on a job.
OccupantRJ
Eastern North Carolina
I run most every type of sander normally available, but I am using them on machinery instead of wood. I lost a vibratory finishing sander in a flood 20 years ago, and never bothered to replace it. The handheld belt sander is my next least used sander, as I do not do much woodwork anymore. I could fill up a commercial wheelbarrow with the various sanders and grinders I have in the shop. Each one gets used, and they all have their place in doing so.
jonshonda
Wisconsin
Is this a question, an answer, or just rambling? Bosch 1250DEVS is said to be a great compromise between belt and orbit
Downwindtracker 2
BC
For most my woodworking I use a Makita 3x24 loaded with 120 grit and a DeWalt 1/4 sheet loaded with 220 grit, stearate coated. Finish sanding, between coats of varnish. I have an early Bosch 5" RO . It's too rough running for steady use.
Parrothead
Earth
OR???
Clearly you’re new to Garage Journal. There is no “or” here. You buy both, sometimes in duplicate. You’re welcome.
