6'' is fine, 8'' if you can afford it
bob
I agree. For use on projects around the house, for smoothing out burrs in metal, for rebeveling or sharpening garden tools (lawn mower blades, hedge shears, loper/prunner blades, etc.) a 6" will work just fine. I own both sizes, Both are Delta grinders, 8" one I used to use on the job and the smaller 6" one has always been for home use. Get one that has variable speeds. You'll likely use the low speed setting for most everything. Bolt it down snug just so it doesn't get knocked over accidentally, but it doesn't need to be toqued down tight like a vise or anything. When mouted on top a solid well built workbench you should have no problem with the bench or grinder vibrating. If the bench vibrates when the grinder is bolted down then you have a severe unbalancing of your grinding wheels or are using those unbalanced wheels at too high of a speed.
As far as sparks go and fire danger, it's always something to keep an eye on. I'd be more aware not to have fuel containers near or anything else that emits flamable vapors. Basically clear the area of anything flamable. Wear goggles or a faceshield too.
For use on edge tools like garden tools, plane blades, and chisels, just keep in mind that it's a grinder. Use it to establish a bevel and get an edge on it. For final sharpening and fine tuning you'll need to smooth things out by hand with a medium/fine grit honing stone or an 8" ******* file depending on the edged tool.
