NuthinFancy
I'm planning my mini-split installation (DIY with a Pro evacuating/filling lineset) and am wondering about bending the lineset.
Looking at the eComfort site, the lineset appears to be a pair of tubes enclosed within their own insulation, but it is unclear if they are attached to each other (figure-8) or separate lines.
If they are figure-8, bending becomes more challenging. If separate, it would seem a manual tubing bending, either coiled-tube type or professional/lever-type would be up to the task.
My installation will require the initial bend (#1) from the exit of wall unit (slightly less than 90 degrees due to angled hole through the wall) to the exterior (going from horizontal to vertical down the exterior wall) then another 90-degree bend (#2) at the bottom of the exterior wall (from vertical to horizontal) and another 90-degree bend (#3) as the lineset approaches the HP, with a likely bend (#4) to reach the HP.
As anyone who has handled thinwall tubing knows, it is all too easy to kink a soft copper line - not something I want to do with a 35-foot lineset.
Any suggestions or recommendations on how to successfully bend the lineset are welcome.
