Bendpak HD-9 wiring question
WhoWhatNow
Collegeville, PA
I din't have one yet but it's in the plans and I am doing the wiring now. Can someone tell me if it needs a 2 or 3 wire 220V outlet.
darkk
Willimantic, Ct.
You need a neutral and two hots, so 3 wires plus ground. Since you asked this question, I would highly advise you to hire an electrician. It shouldn't cost much and may save your life.
PeterT
Toledo Ohio
Two hots and a cot.
Who needs an electrician. Do it yourself and save $300. Just make sure you do your homework.
W
WhoWhatNow
Collegeville, PA
Darkk what does it use the neutral for? I thought you only needed a neutral when there was a portion of the system that needed 110V like a digital readout.
W
WhoWhatNow
Collegeville, PA
I'm pretty comfortable doing the wiring myself. I've run 3 20amp lines and a 50 amp 220 for the welders already. No problems with those.
saabman
Sebago Lake, Maine
I wire my lifts with twistlock pig tails (3 wire). Then I run from the panel above the ceiling and drop it down near the pig tail. The twistlock connection forms my emergency power disconnect.
darkk
Willimantic, Ct.
You ask these questions? And you're comfortable doing the wiring? I'm going to repeat myself, hire an electrician before you kill yourself....
W
WhoWhatNow
Collegeville, PA
The 10/3 was only $15 more than the 10/2 do I picked it up on the off chance I need the neutral line for something down the road. Thanks.
