Bendpak MD-6XP ---- Summit Racing
baducduc
Sorry to post about another scissor lift but I want to give props to Summit Racing for holding up their end of the deal on delivering a new MD-6XP lfit to my home for $1915 total. Con-Way just dropped the lift off and the delivery person not only helped put the lift into the garage - he helped me take the lift off the pallet and took the pallet with him for disposal. This lift is HEAVY! Big thanks to Vito at Summit Racing! :thumbup:
Until I recess into the ground I'm going with 2x3 and 3/4" plywood for a 16" wide platform. Looking forward to using the lift soon!
baducduc
It is worth recessing it in the ground...trust me!
Until I get the motivation to tackle recessing (and finishing the garage) this will have to do for now. Finished the ramps last night, 2x3x11 topped with 3/4" plywood and 6 stringers for extra support. This is going to make working on cars that much easier, and more fun!
GH85Carrera
Oklahoma City, OK
I have the same MD6XP. I is wonderful to have it recessed into the floor. I hated parking on the wood ramps.
The one thing I wonder about is the metal tabs at the ends that prevent the arms from rotating all the way. The tabs are always in the way for my needs. I may just cut them off.
The Porsche is with the pit. The Elky is before the pit. I ended up cutting a trench over to the wall and mounting the pump on the wall.
The arrow points to the tabs I may cut off. I can't see any real purpose for them except to get in the way. :shocking:
baducduc
How deep did you recess you lift? Do you notice the lost height for wheel/brake work?
Also, one of the bolts for the arms is barely showing once the nut was tightened. Should I be concerned and call the factory or just leave it be?
This shows how the other 3 bolts are secured:
GH85Carrera
Oklahoma City, OK
My pit is just under 9 inches deep. It is the height of the lift all the way down with the lift pads on it. I can use the lift pads to support a piece of plywood I use to cover the pit.
kerryt1
Oklahoma
Get yourself some longer bolts. You should have 2-3 threads showing on any structural bolted joints. I'd go with grade 8 also. Those look like locking nuts also, is that correct. Either way, you definitely want some whether they are nylock, elliptical, or whatever.
baducduc
Agreed I would feel safer with a few threads past the nut. Unfortunately the bolt is integral to the arm so I can't install a longer bolt. Can other MD6XP owners please check and verify your arm bolts? Thanks
New London Twp, Ohio
Mine is the exact same lift with an Eagle sticker on it, about 7 years old. I just checked the bolts, mine are castle nuts with cotter pins... bolt is flush with the nut. I am embarassed to say that at this moment mine is being used as a works bench with an IRS from a Jag disassembled on it, but I do have a 10000lb Bend Pak 2 post lift as well
GH85Carrera
Oklahoma City, OK
All 4 of mine have a few threads sticking out through the nut. The nut is a big nylock style on mine.
JakeKohl
Greenville, SC
A couple of extra threads showing does nothing to the strength or security of the bolt and nut (other than making a few of you feel better). There is plenty of exposed thread with that bolt. I wouldn't hesitate to engineer the fasteners that way if the clearance was needed.
