I purchased a model XPR-10A 2 post lift, when the vehicle is on the lift it leans to one side. I called BendPak support and told them of the lean. Without the tech investigating further I was told to "put the arms together, if their off, shim one side until their level”. I told him my posts were plumb and shimming them now would put them out of plumb and possibly mask another issue. I was told “an out of plumb post would be fine”. The tech told me I over tighten the base plate nuts when I mentioned I torqued them down to 95 ft lbs. When I stated the direction call for 95 ft lbs he said “oh, I guess its ok then”.
After ending our conversation I wasn’t comfortable with his plan for a fix so I called BendPak support again hoping to talk to another tech. I talked to tech named Tollman he seemed interested and helpful he asked me to take pictures of the arms together and send them in for his boss to review. I was told he would call back later that day or the next day. When the next day came without a call I called BendPak again and was disconnected while talking to my third tech. It’s been two days I haven’t heard back from BenPak and thought I’d post asking for your thoughts.
Both posts are plumb when unloaded and loaded. While in the locked position the arm base is level, the arm extensions are not.
Looking at the pic the power side post is on the left and non-power side on right. This is the strange part, when loaded the non power side rear arm is 1-1/4” lower then the power side rear arm. The front non-power arm is 3/4” lower then the power side front arm. When unloaded both power side post’s arms are lower then the non-power side (pictured).
I’m ruling out the floor being uneven base on the plumb posts and level arm base. Also ruling out the cables because their sitting in the locked position.
Arm base is level.
Arm base is level.
