New install of a XPR-10AS-LP narrow configuration.
The arm on the power side seem to move up first and is higher than the other side.
When I set the lift down on its locks, the arms are level.
When I start going up, it looks like the power side goes first and then the equalizer cable for the left side tightens up and then its pulling the left side up. So the height difference is the slack in the cable.
Not sure about the role the equalizer cable plays is this process. The cable on the power side does not seem to be under much tension.
How do I get both sides to go up together.
Also, could it be that the cyclinder is not working on the other side and the arms are just being pulled up by the cables?
Sorry with so many questions... noob here.
