Best Air Hammer
V4F
Wichita, KS
Who makes the best air hammer? For heavy duty automotive type work.
Exhaust stuff, removing kingpins, general destruction, etc. . .
I assume it needs to be a "long barrel" style, but what brand?
I have heard CP Industrial, Mac, and Snap On from different people.
I am looking for the most "hitting power".
Anybody have any favorites?
35mastr
Norcal
Snap On. I have one that I have even used to break concrete in a fence post hole with a long bit. Worked like a charm.
V
V4F
Wichita, KS
petty4243
LuVerne Iowa
do some research, you will find Ingersoll rand is one of the best... any of s/o and macs air tools are ade by them... you could have same tool for a bit less money...
Diesel-Mech
Kansas
You are correct that many Mac tools are made by IR, You are wrong about Snap-on though almost every air tool with the SO name on it is designed and made in house by them.
Big Bad Jon
I have the Mac AH750K and it has done everything I need for cars and light trucks. I hope this is helpful.
petty4243
LuVerne Iowa
I can not argue about all of the air tools, but i do know the air ratchets are made by ingersoll rand.... I own a ingersoll 109xp and coworker has a snap on FAR72C... the only variance between them in ine has a industrial finish on the ratchet head while his has the typical snappy high polish chrome... everything else is the same...
please keep in mind that i am just using it as one example.... and am sure there are more....
basic contex of my post is that a little bit of research can save a lot of money...
if you are using it professionaly it might be worth spending the extra and getting snappy/mac just because of their it might be easier to get the to help with warranty issues if they come up ..
just my 2 cents worth
Marlin
Many of the ratchets on the market have interchangable parts but IR does not make any ratchets for Snap On. (or air hammers)
Spookrider
Eaton, Indiana
My dad CP 714 bought in 1965 still kicks like a mule and the IR 121 to replace/second duty the CP714 kicks like mule also. Our shop senior tech uses a C-Man air hammer bought long time ago for all his work still to this day.
fordracing200
as hilarious as it sounds, I have a HF one, I've had it for years, has sat in a box since i moved, pulled it out the other day, havent touched it since 00 and has never been oiled, worked like a charm, oiled it, works good. I see they went on sale for 4.99 the other day...for that price...haha. I know I know, HF *****.
vc-onthepc
maryland
Prefers Mac long barrel had for about 12 years now and still going strong . Im a diesel/heavy truck and equipment mechanic by trade .
My dad has a has a import "harbor freight " style and honestly for the money ... it's ok for general use and if it broke who cares ... well my dads is older then my mac and still going strong.
the cheap bits though thats another story altogether . buy better ones they do last longer and just make sure whatever one you buy it has the universal chuck /stem diameter i think its .409 or something like that ?
garfunkle24
Saskatoon, Canada
This is the hammer I use, a Snap-on PH3050:
It is definitely the most powerful air hammer I've used and 99% of the time I actually have the power dialled back to some degree.
It's very nice tool but it was quite pricey. The only other thing I would add is that with a good air supply and the power wide open, these things will really eat through the bits in a hurry.
SteveU
Here's one even more than that, this one uses .498 chisels instead of the .401 that most air hammers use. Looks like the more expensive one is more heavy duty & the cheaper one is for more general work.
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=10860
garfunkle24
Saskatoon, Canada
