woody 73
I have good luck with the goodyear red hose,just my two cents...
You are kidding right? It's either coil or hard nylon line. I kept brake line and a selection of push connectors in my wrecker because it was a constant, everyday thing for that nylon hose to burst on local trucks. It's not made to flex any distance. Using that stuff is just asking to get hurt.
Usually they break on the road because they get pinched and cut from the twisting and turning of the truck/trailer pivot.They make great hoses for overhead at the work bench.just a heavier version of a normal coiled air hose.The orange goodyear Pliovic hoses that are sold are HF and other stores are good. Easy to wipe the hose clean after use.
http://www.harborfreight.com/media/...ab33525d08d6e5fb8d27136e95/i/m/image_2141.jpg
I've put several of these in 25' to 50' lengths to the test, and they've been the best I could find, though I haven't tried the flexzilla. This post is from a previous thread I started.
Parker air hose, made in USA, 3/8 ID and 11/16 OD:
Parker air hose is excellent quality stuff, IMO. I have experience with hundreds of hoses made from it. Very durable, coils well, made in USA. Pushing the fittings in isn't easy when making a new hose, but they stay there!
FYI:
http://www.controlandpower.com/catalog/PDFs/Parker/Parker Hose Products/Parker HPD 4281-0203.pdf
At home I went through several really cheap Central Pneumatic hoses until I switched to the black Goodyear hose from HF. It's good so far (2+ years).
Harbor Freight has the black Goodyear 3/8" ID made-in-USA 50' length for $25.
http://www.harborfreight.com/merchandising-promotions/merchandising/presidents-day-sale-2/50-ft-x-3-8-eighth-inch-heavy-duty-black-rubber-air-hose-2167.html
THIS HOSE IS AWESOME!! Does not attract grease, does not break down, stays pliable, very good stuff.
There is a hose/lube supply company that serviced my old dealership and every hose in the shop was this type. Never ever, ever did it need to be replaced. Now, at our new shop, all out hoses were ****.
I snuck back over to old shop one day, read the hose to figure out where it came from, then went online and bought a 500 ft roll to replace every hose in the shop.
Also bought a crimping tool and ferrules.
+3 on the GoodYear hoses ..
It happens. I think for the most part the Goodyear hose is good stuff on the cheap.
Hi. I'd joined my family business of manufacturing and exporting air, water and welding hoses from India a few months back and have been involved in quality control and r&d.
I stumbled upon this thread and it seems like a very good source. I mean, ultimately, you all are going to judge the product. We do sell to many stores in the US and until recently the quality was average, but now we are improving and trying to give the best value products. (I know they compete with 'made in US' products, but we gotta eat too
There is little trend of diy here in India, and you guys seem pretty serious about all this, so if you could help me make a better product that'd be kind. In return, maybe, I can send some free samples to get some beta testing results.
I know the question's too vague but what exactly do each of you look for in an air hose?
For example, if the use is static under sun, we'd make it in EPDM and it would last really long.
If it is dynamic (includes run over by a carunder sun, we'd use a blend of neoprene and natural rubber with sufficient ozone resistance and great strength.
If it is dynamic/ static inside, we'd go for natural rubber only.
If it involves slight contact with oils, then EPDM. Substantial contact, NBR. Then again, it depends - which oils?
I'd be glad to send free samples. We have a warehouse in the US too. Any help will do.
- just another kid trying to learn good, fair business.
I'm in for a free sample too...
As previously stated, a hose that does everything would be perfect, but since we don't live in a perfect world, each person's application will differ.
Personally, I have a shop where I mix uses between Automotive, painting, metal working, and woodworking, both indoors and outdoors. I need a hose that stays flexible, has good abrasion resistance, better chemical and oil resistance, has good kink and stress resistance, and is light weight.
I have tried all types of hoses, PVC, rubber, vinyl, EPDM, and combinations. there doesn't seem to be one good hose for all occasions. I have been using the EPDM, and Rubber combinations, they stay soft and flexible, have somewhat good oil and chemical resistance, but are heavy in comparison to the PVC and Vinyl.
