american21
- Joined
- Mar 14, 2015
- Messages
- 46
Looking at the kobalt 3/8 clicker for 60 anything good cheaper? Will be for small engines motorcyle and cars
The $10 (on sale) harborfreight torque wrenches are generally quite well received.
At least the older Taiwan ones are. You might only be able to find Chinese stock by now.
I would highly recommend Precision Instruments torque wrenches. They are a bit more expensive than the Husky/Kobalt (can be had for around $100-$120) but the build quality is fantastic IMO.
My vote as well. Precision Instruments used to make the split beam torque wrenches for Snap On for many years, same exact wrench just different colored label insert. Funny watching people on eBay pay almost $300 for a used Snap On branded wrench they could of bought brand new from PI for half the price.
The harbor freight ones work well for me and at $10 you can't beat the price.
They are cheap and accurate but here's the rest of the story.
1. The click is real wimpy and you might not even hear/feel it. If you don't you could shear or over torque the fastener.
2. The adjustment range is real small. You go from low to max. in around 1" on the scale. The scale is really hard to read it's so small.
3. The adjustment knob goes from real loose to real tight and has a rough feel. It just doesn't feel right. I think they use a real short spring.
Hi there!
I just bought the 1/2" drive Husky and 3/8" drive Husky. 1/2" goes 50-250 ft.lbs, and the 3/8" is 20-100 ft.lbs (I think). Both were made in the U.S. and came with a calibration report.
HF unit matched my brother's (he is a professional mechanic) SnapOn exactly.
I had about 20 bolts to torque to 50 nm and the place I was working for had "Sonic" branded 3/8 clicker wrench I used. Probably a year old. Just for fun I placed my digital torque adaptor on the wrench and set it to read the max torque - testing the wrench on each bolt. I was rather impressed, the readings were almost spot on every time, ranging between 49,8-50,1
My guess is the wrench is Taiwan made.
Similar test - about a year ago sent two top Euro brand wrenches to the trash bin. To be fair both of them had seen lots of bolts in a busy diesel shop.
Surprised no one has mentioned the Craftsman torque wrench. $30 when on sale with points. Snapped bolts with HF torque wrenches before. Never again.
That is funny.
I had a torque tester for a few weeks and tested a number of different torque wrenches with a number of different operators. Several of the guys had over 30 years torquing wheels on race cars and other critical items.
None of them were able to get consistent results with a HF, yet with craftsman, CDI and Snap On the results were plotable and consistent.
It is real hard to accept that at 9.95 the out come is going to be good.
I was surprised by the results also, it clicked correctly EVERY TIME! We weren't torquing on wheels either, all the work was under the hood inside the engine. I felt so confident on this unit, after testing it I used the HF for the job while the SnapOn was left sitting on the bench.
Have a link to the 1/2in? I'm needing a new one. Love my 3/8 husky.Hi there!
How would you know if you were not using a torque tester?
