Best concrete floor coating value ?????
mmmm
Two and a half months ago I poured a new concrete floor in my new steel barn. Currently nothing has ever been on it because I planned to paint it. My original plan was to just go to a big box store and get something reasonable. Quickly is decided maybe I should talk to someone more knowledgable and went to Sherwin-Williams. The '20yr old' sales guy recommeded ShieldCoat. It is on sale for $59 per kit, and at 1100sqft. I will need three for a total of $180.
This barn will be used basically for storage. It will contain a bit of racking and have some of my cars and other toys parked in it. The cars will probably be used less than once a month. Some of them will be stationary for a year at a time. Occasionally I will get the wenches out and change the oil, or jack up the vehicals to change the brakes. As I said this barn was erected mainly for starage.
Floor painting is attractive to me because of the ease of cleanup, the lack of concrete dust, and the resitstance from stains. I am looking to paint the floor and then have minimal maintance. For that reason I as scared of products that may be likely to peel a couple of years down the road. From what I gather, if the coating peels, the surface must be stripped and then reapplied. I personally would rather that the surface would wear thin rather than peel. I figure wearing thin will just require another coat?
I began looking a epoxy coatings online. I found a company named Durall who makes Dura Seal 400. Their kit for my floor is two coats and costs about $500. It dries at about 9mils.
I poured the concrete myself at a cost of only around $1100, so I would rather not spend too much on the floor coating. Yet I am still leary of peeling.
???? MY QUESTION IS ????: The latex based ShieldCoat finishes at about 3mils and costs about $180. Its it worth the extra money to put a single coat of Dura Seal 400 on (4.5mils)? It will cost about $290 or an extra $110. I have been told the first coat will not be that even, but how bad is it? I am not that picky, however I don't want it to look horrible.
I think I can swing the $300 tab, but would rather not spend the $500. Another attraction is that Durall says it can add anther coat an any time.
PLEASE let me know how you feel I cant get the best value out of my floor while staying within my $300 cap.
Thanks in advance,
Matt
Luckydevil
Tampa
I highly recommend Rustoleum Professional Epoxyshield. I've had mine for over four years now and I beat the hell out of it. It has held up wonderfully and I'll be putting it in the garage of my new house as well. It's an excellent value for the price.
I found it online for $94 per kit (300-400ft^2 per kit). Looking at three kits that would put you right at your budget.
This is the cheapest I found it online and it is typically very hard to find in any stores.
http://garage-toys.com/epprflco.html
Here is a thread with some more good info on it.
http://www.garagejournal.com/forum/showthread.php?t=379
back2class
All finishes will get damaged at some point. peel, gouged and on. If you MUST paint then 2 part epoxy is the best product. All typical brands should be good. I would never paint a garage floor. Will just end up looking like **** one day if you do much with it. At least if you do real work! If it's just dust and easy cleanup a few gallons of polymer floor sealer like they use on industrial floors will fix that and give the floor some resistance to spills and oil. Plus it can be strpped easy or re-coated if need be. Cost is about $12 a gal. It s not all that different than thinned out water based polyurethane.
back2class
Re: rolex watches-0829
Top quality Japanese Rolex watches Automatic Rolex watches Movement with Smooth Sweeping Seconds Hand,41mm Satin & Polished finish case,Solid back featuring all the necessary markings on it,Solid black stainless steel bezel with tachymetre,Black corrosion-proof dial with Luminescent Stick hour Marking, date displays at 3 o′rolex watches clock position,Sapphire Crystal - Scratch Resistant, Cambered,Luxurious 316 stainless steel caterpillar type bracelet, easily rolex watches adjusts to any wrist,Fold-Over-Clasp-With-Safety,Enjoys the same feel and weight as original,Water resistant, but we do not recommend you to swim with the Watch,Box Set :NO/YES ( + $25 )(Box only be sold with the replica watches watches, we do not sell box solely.)
Thanks for the spam! We really appreciate it here.
M
mmmm
Sealer
One more quick question. Sealler? At stores with concrete floors such as HomeDepot and Lowes, the floor has a clear, smooth, easily sweepable and cleanable finish. It that just a sealer or is it some sort of clear epoxy. It looks rather thick. What is it and what are the different thicknesses needed for different uses, my use being mainly storage and minimal shop work.
M
mmmm
Sealer??
Does anyone have any thoughts on using a sealer for my application?? (please read first post)
Thanks,
Matt
AlphaGarage
Every Garage, AnyTown, USA
We do offer a sealer which may fit your requirements. It's a one component acrylic sealer that cures to a transparent glossy finish. It's resistant to most common shop chemicals.
We recommend an acid etch to prep.
It's Acrylisel 3501, 5 gallons will coat 1,500 ft2 with one coat, we recommend 2 coats. You can also water down the first coat with warm water (50/50), the will give a higher gloss finish, plust stretch out the coverage a bit.
Last week I went to a warehouse that applied it, they needed a facility pretty much improved and ready to use in 2 days, so our contractor opted for the AcryliSeal. The floor looks great and is holding up well. Even the forklift wheels aren't damaging it, they are very pleased with the results.
