I rounded off a starter bolt on a 2010 Mazda6 and need an easy out to get the bolt out. I have very limited room, too. I have tried other easy out's (Irwin and Craftsman) and none have come close to gripping the bolt head. It is a 13mm hex head. I don't want to have to cut the bolt out or grind the head off. That would make things worse IMO. Anyone have any suggestions on a tool or better easy out to use? I have also tried vise grips, pipe wrench, gator grip etc., but like I said, limited room and no luck. That bolt is torqued in there good as well. And remember, steel bolt in a aluminum block with no anti-seize. Thanks for any help! Ethan
