anndel
Hein Werner, had the 2 ton version for 8 years now and so far no problems, I guess it's time to lube the moving parts and check the jack oil level.
So glad i purchased a Hein-Werner 3-ton a few years back.
I think it was around $465 shipped (Tool Topia)....they are HEAVY duty.
Agreed! Love this jack. Picked one up in August from Zoro tools. Got it when they were having a 30% off sale, around $360 w/ free shipping. When lowering it, it was very touchy but is great now after some use. Highly recommend.
I am going to piggyback on the OP's thread, as I am also looking at buying a new jack, so hopefully he won't mind.
Have any of you extensively used the Arcan XL35?
http://www.northerntool.com/shop/tools/product_200345429_200345429
AC Hydraulic products were mentioned in several posts on page 1 of this thread. They look similar to Compac floor jacks that are also manufactured in Denmark.I haven't used most of what's been posted here but a friend has one from AC Hydraulic and I really liked it. Sorta surprised that wasn't mentioned here - or maybe the quality isn't that great? The best part for me was that the wheels have o-rings to dampen noise when rolling the jack around - makes a HUGE difference.
http://www.pelicanparts.com/catalog/tools/AC-Hydraulic1.htm
As a reminder for the newer folks, the jack is only to LIFT the vehicle, once lifted, it should be supported by jackstands with a safety pin
The jack itself shouldn't hold the weight of the vehicle. Then get redundant and put extra items underneath the car (tires, large blocks of wood, etc.) and shake the vehicle aggressively before going under.
Safety pins were for old diapers! I like pawls. At one point I was looking for dual locks-pawls and a slug pin to hold the weight too, I think Torin made them. But then it kind of dawned on me that it would be false confidence. The jack stands could still slip and possibly kick over. I kind of figured to leave well enough alone, you know? It may sound bad since it is the most important tool, but putting all your worries into the latching mechanisms and forgetting the frame could collapse, the ground could sink, the stands could tip over, or any other unforeseen instance.
Where are you finding a Milwaukee model 20 jack for $700? They are all closer to $900 online.
I was about to pull the trigger on a Milwaukee 20 in early Aug. until I received the quote... still looking for a good used jack as it is hard to justify $695 for a 2 ton jack (35% price jump in July), although I still like that they are 100% USA and local to me.
In the meantime, my 20 year old import does the job and the 50 year old Weaver I am restoring will be put into use once complete.
how about american forge and foundry(AFF) http://www.affjaxx.com/ im looking to get 1 too.i herd u can get replacment parts for them too if needed.
