Best overall floor jack?
Madhat
Ottawa
Located in Canada, looking for a mechanically sound jack that I can keep for a long time.
Are there any brands that are better than others? Any features I should be looking for?
outwestjake
Pennsylvania
Hi Madhat!
I am new to this forum, however, I am currently in the same boat as you. I recently acquired a brand new Torin floor jack with jack stands, however, I became very disappointed in its performance. The bleed off is very aggressive, you have to turn the handle very, very carefully if you don't want to drop your car back down as if you just yanked the jack right out from underneath it.
I recently came across an old jack, on facebook marketplace for $10. I am hoping to get a positive ID on it and rebuild it so that it can be "THE" jack for my garage. I miss using my father's old jack that he is still currently using. So I wanted to find one for myself to serve my needs for a long time.
Good luck to you!
driz
Northern NY
Hi Madhat!
Good luck to you!
Somewhere out there is a complete guide to rebuilding jacks with pictures and parts references. It was part of a thread on some mechanical forum say 15 years back. Look around it’s probably still there. Many of those seals are generic.
HoosierBuddy
Southern Indiana
I'm on my third floor jack now I guess (in 30 years), plus I've bought a few for work...so that's my basis to say:
Features:
Aluminum - My current floor jack is aluminum and I appreciate that it is lighter and easier to maneuver because of this. Sometimes you end up wrestling the jack over uneven surfaces, grates or drains, etc....lighter is better.
Quick Rise Feature - My last 2 jacks have had the quick rise feature where they move up quickly with a pump or two until they press up against the load, then they pump normally.
Final feature you need is good jack stands to go with your new floor jack. Remember the floor jack is just for lifting. You can't safely work on anything until you get the jack stands under it.
Good luck!
Phil
pbon
I have a Michelin 3.5 ton jack from Sams club that cost $79 on sale I think and is about 10 years old. Also have a couple of the light aluminum HF 1.5 ton jacks that go for $59 on sale.
I don’t think you need to spend $600 on a jack unless you want to. Maybe spend $1200 on a quick jack. Arcan, Sunex, Torin, HF and others are worth looking at.
ooba tooba
I haven’t had an issue yet with my Pittsburgh 3ton racing model. Aluminum. Quick lift. Low enough to get under the wife’s Charger, and goes high enough to lift my Ram.
lowside67
Vancouver, BC
I am also in Canada and have had an OTC aluminum racing jack for the last 10 years or so:
https://www.otctools.com/products/2-ton-capacity-aluminum-racing-jack
It has not required so much as a set of seals despite being well used and then sitting for extended periods of time. For the money, I feel like this is one of the products I feel like I am most pleased with the value I got.
-Mark
bobcatdan
Kaukauna,WI
I have a long frame blackhawk jack from my guess the 40's, very art deco in its design. To my knowledge it has not been rebuilt, at least in my life time. I can't think of a modern jack I would replace it with.
EZ_Garage
US of A
Certainly not the best but I purchased an Arcan from Costco about 3 years ago because of the liberal return policies and relative low price (~$100). I purchased an all steel version over the "hybrid" aluminum/steel version but that was just a personal preference. It was the Arcan XL3000 Steel version that was offered in-store, it has a low profile and high lift capacity: 3" to 19.72" Lift. With those specs it will get under the sedans and lift the SUV and trucks that I have in the driveway. Just my $0.02 and I know you were asking for the "best" and I probably didn't help you in that regard. :shocking:
paulsomlo
Northern Colorado
Best overall? New or used?
New - Weaver, Milwaukee, AC Hydraulics, Compaq (be prepared to spend some cash)
Used - Blackhawk, Hein Werner, Lincoln (As in old USA, but be prepared for a project)
BrandoJames
Tornado Alley
Madhat
Ottawa
Daytona DJ3000 3 Ton floor jack from Harbor Freight. Cost right around $200, excellent jack--highly recommended. This floor jack was the focus of a bitter lawsuit between Snap-on and Harbor Freight over copyright infringement.
Was looking at this one, not available in Canada unfortunately. There is this one from princess auto though:
*Nvm can't post links yet*
But if you google : 3 Ton Low Profile Super Duty Floor Jack
It's all black.
Madhat
Ottawa
The older I get the more I appreciate things just working. I have heard good things from Arcan. Might have to check that out. 150$ CAD..can buy a lot of jacks for that.
johninct
You asked for the best.... Milwaukee Hydraulic but it is very expensive. Next would be one like a Snap-on YA-700 I think it is now made by Walker or Hein Warner. Napa has had some good ones too. I have the Harbor Freight yellow one that I got a killer deal on and I think it is ok but an sure is not repairable .
TJKamp
Sweet Home, TX
Not sure if they are available for purchase in Canada, but I’ve been using this ACDelco 3.5 ton floor jack for 17 years now with no issue Weekend warrior type stuff, not professionally. Although, these are the jacks that most of the professional shops around my area use.
I recently purchased a new one, wanted a second one to have two when working on the suspension on my Jeep. The design on the new one is slightly different than that of the old, but not by very much. It feels just as solid as the old one, and I’m sure will provide years of service. Not sure what it would cost up there, but in Texas they are about $220 USD.
They are very heavy, but I’m ok with that in a floor jack.
https://www.oreillyauto.com/detail/...ack/34700/2494193?q=AC+DElco+floor+jack&pos=4
Farmall450
Marengo, Illinois
Honestly, NAPA's 3 ton, as well as Harbor Freight's newer 3 ton are both excellent jacks that have been taking a beating for years at our shop. The HF model has been shown to be identical to Snap-on's on this very forum (minus the seals) for $179. I also believe Larin is now using this same OEM for their nicer units.
Steve_P
I have the HW 2 ton and really like it. I also have an AC which is also nice. And I have a HF, but I'd never buy another one as I've had no luck with them lasting.
Doughnuts
New jersy
Hein Werner. They used to be sold under the brand name of lincoln as well. Theyre pricey but the best jack ive ever used hands down. Probably find one on fb marketplace that outlast you
Ralf11
Nothing competes with AC Hydraulics for automotive use. Definitely a buy it for life kind of jack.
True, esp. for low clearance cars.
OTOH, nothing competes with their price either.
I have a Norco and an Al "racing" jack from Crapsman before Sears folded.
Usually the pump goes out on jacks, so get one with a new seal kit.
noid
Pay once, cry once.... er I mean pay twice cry twice since I have two AC jacks.
MJK
Tucson, AZ
I had a failure on a cheap and portable aluminum 'racing' jack 15 years ago, which scared the **** out of me. I decided right there that I'd made a serious error in how I was evaluating what was important in a jack. It was replaced with an AC DK13HLQ, and I have never regretted it. Pelican parts still has service kits available, although I have never needed one.
I wish they made a 3-4 ton version of it for my heavier vehicles.
noid
I too have had a couple experiences when I was younger with jacks suddenly failing; also came out of those with the same mentality.
DK20HLQ or the DK50HLQ should fit your bill? Remember, you're only ever picking up at most half of the vehicle.
Rattle
Vancouver, bc
I have the 3 ton from Canadian tire. Normally $200 and it is on sale right now for $120. Definitely better and lighter ones but a solid option.
pbon
I have never had a $600 jack. The 6 jacks I have owned in the past 25 years cost half that in total and all but one are still in operation. The one that is not got left outside one winter in the snow and I did not bother trying to take it apart to fix.
If I owned a shop and used the jack every day, I’d buy a fancier one. If I had a bunch of money and could buy whatever I wanted, I’d have a fancier jack. But for me “best overall” means a combination of factors are taken into account. “Best that money can buy” is a simpler analysis and probably does lead to a $600 jack.
Regardless of how expensive a jack you buy, use jack stands or other safeguards when under the car. I think you can get a good jack in the $200 range, though none of mine cost half that.
sberry
Brethren, Michigan
My Bud bought a 5t long frame HF, not sure they make it any more, was about 200 or 225 at the time but used it every day, several times for 25 years.
marantzer
ATL
Looks like the 13 long reach is newer, any deals out there for them?
Not sure if you're looking for the long reach or the DK20Q, but right now on Amazon they are about $60 cheaper than normal. I purchased from B2C Auto and at ~$340 a few days ago and my order was promptly cancelled. Another seller, Tire Tools Direct, had the same price so I ordered from them last week and the jack arrived Friday. It was the lowest price I've seen since I started following them.
Ralf11
The "deal" on the Danish jack is that they are now imported or distributed by several places - years ago they were new & unusual, an a LOT more expensive than they are now...
PCMusicGuy
Houston, TX
The overall best floor jack is not something that is a one size fits all. It's best for purpose.
I have the Omega 29023 (stock picture attached) that I use for my low cars. It's the only floor jack with slightly lower/better reach than the AC Hydraulic low profile long reach jack. It is stupid heavy though. I wish AC Hydraulic still offered their aftermarket non-marring wheels. Some of those were pretty trick ( I remember a bright orange set.)
If you are running a pit for a race car, maybe you'd want a brunnhoelzl or hyjack. Quite a bit lighter, but more expensive.
