Best overall floor jack?
Qualitytools
SOCAL
Not sure if you're looking for the long reach or the DK20Q, but right now on Amazon they are about $60 cheaper than normal. I purchased from B2C Auto and at ~$340 a few days ago and my order was promptly cancelled. Another seller, Tire Tools Direct, had the same price so I ordered from them last week and the jack arrived Friday. It was the lowest price I've seen since I started following them.
I have the 20 and was thinking of getting the 13. In fact I think I purchased it from TIRE TOOL DIRECT back 15 years or so. Do you have a link for them? Thanks
Qualitytools
SOCAL
They never really go on any kind of substantial sales; ECS tuning sometimes has them for $50 off.
I ordered mine from Amazon (through a third party seller) because it had the cheapest shipping to Canada.
Thanks! :)
Qualitytools
SOCAL
The "deal" on the Danish jack is that they are now imported or distributed by several places - years ago they were new & unusual, an a LOT more expensive than they are now...
I am not so sure about that as I purchased mine about 15 years ago or so and found my DK20 cheaper than they are now but can't remember what I paid exactly
Buckaroo5
Central Ohio
Certainly not the best but I purchased an Arcan from Costco about 3 years ago because of the liberal return policies and relative low price (~$100). I purchased an all steel version over the "hybrid" aluminum/steel version but that was just a personal preference. It was the Arcan XL3000 Steel version that was offered in-store, it has a low profile and high lift capacity: 3" to 19.72" Lift. With those specs it will get under the sedans and lift the SUV and trucks that I have in the driveway. Just my $0.02 and I know you were asking for the "best" and I probably didn't help you in that regard. :shocking:
I have an Arcan jack purchased from Costco ~10 years ago and I have been very happy with it. It's the all steel version and the label rating says 3.25 ton (XL325R) - I think it was the standard 3.5 ton made by Arcan but they derated it to sell at Costco cheap. It still works great - you do have to slowly open the valve to lower the vehicle but you quickly get the hang of it. Not daily use - probably every two weeks or so.
marantzer
ATL
Sorry, I should have been more clear. Tire Tool Direct is one of the Amazon Marketplace sellers now. So I bought it on Amazon's site, just selected the aforementioned seller.
noid
Anyone have experience with Esco jacks?
This looks interesting (Esco 3 ton floor jack made in Demark)
Yes they are quality units.
Compac is the actual danish company making them; Esco is a subbrand.
They seem to be slightly more conservative in the sense that they don't aim to have the lowest profile or the biggest lifting range. However, solid well made units meant to last a lifetime just like the AC units.
Edit: I take that back, their new 1,4T-HC 77 looks to hit the spot just like the DK13HLQ
https://www.compac.dk/en/products/jacks-1-5-3-ton/high-lift-jacks-1-5-3-ton/1-5t-hc-black-detail#
MJK
Tucson, AZ
Interesting, thank you for that and your earlier suggestions!
I'd love to stay with AC to lift my 7800lb truck's front end, but not at the prices I am seeing for DK40s or DK50s.
ex-x-fire
Sheboygan Falls Wi.
I'd say that early versions of the import jack is a good jack, these were made in Japan in the 70s. Everyone I see is claimed to be original and still working. My fil has one and it just works.
dubdoc
Milford Station, N.S.
I got this 3 ton "Certified" from Canadian Tire after using up 2 smaller ones. It came with 2 good jack stands and has been flawless for over 8 years now.
bubinga
I heard about Costco's liberal return policy.
We don't have one around here unfortunately, but is it true they'll pretty much take the Jack back anytime?
bubinga
Was looking at this one, not available in Canada unfortunately. There is this one from princess auto though:
*Nvm can't post links yet*
But if you google : 3 Ton Low Profile Super Duty Floor Jack
It's all black.
I could be wrong but if this is the right seal kit I have linked to, it looks like it would have the better
seals too the Jack itself looks just like the Daytona only maybe with the better seals.
I could be all wrong though I'm just sort of learning about this stuff
This is the jack.
anndel
Hawaii, USA
I have had the same exact HW jack for about 8 years now, very good quality. I’m quite sure it will outlive me. Made in USA is what sold me
Have the same for 16 years and so far only replace the jack oil every year and grease the *******. I bought a 3 ton 2 yeas ago and use both.
MJK
Tucson, AZ
I added a DK20HLQ to go with my 10 year old DK13HLQ. It lifts the front of my 7800lb truck without issue.
Pelican has rebuild kits for both in stock, although I have yet to need them. No regrets here.
IMO the only reason not to have the DK13HLQ would be cost, space or if you are working on heavier vehicles. Long reach, smooth release, high lift, easy to move around. Mine has been under numerous low profile sports cars where nothing else I've ever had would reach. e.g. the center jacking points on E46M3s with the car flat on the ground so that the outer jacking points can be used for jack stands.
Badgerstate
Columbus, OH
Located in Canada, looking for a mechanically sound jack that I can keep for a long time.
Are there any brands that are better than others? Any features I should be looking for?
I like my Craftsman 3-ton floor jack a lot. Its all steel and built like a tank. IMO, you dont need to go out and get a high-end jack but you definetly dont want to cheap out on something that you are lifting cars up with.
bubinga
I ordered the AC hydraulics DK13HLQ from Amazon warehouse.
I have a feeling the bolts they are referring to are going to be missing, they do show a picture of mounting the top handle but they don't show a picture of the bottom where they say,
Then place lever in tipping gear, and secure it with tip-
ping gear screw fitting into slot in tube lever.
Is that pretty much self-explanatory?
And with the screw or bolt I need be pretty much self-explanatory?
Also they say,
Important: It is mandatory to lubricate axle
(9106200/9106900) for tipping gear every month! If
not you risk “long” holes in the pump – and this is NO
warranty!
Again they don't show an illustration is this pretty much self-explanatory?
I'm probably not going to be using the Jack everyday either.
They say if not you risk long holes in the pump. I guess they're talking about wallowing out holes in the pump somewhere?
If these units would require warranty, we are not responsible for shipping this to Denmark I hope?
Sneezer
DFW, TX
Yes. Some years ago I bought an aluminum 3 ton jack from them. Worked great for many years, then the seals started leaking. I checked around but didn't have much luck figuring out what size or type seals to get. We were not on a good financial spot either, so took it back no issues. Went to HF and bought a $50 jack instead. Been many years with it, still works but I hope to get a Daytona or the long reach low profile soon.
MJK
Tucson, AZ
I have no idea how to answer that. The jack comes more or less assembled:
- main unit minus saddle and handle
- the saddle cup. Saddle cup pad is an accessory
- the handle tube. Screw to retain tube on the bottom is part of main unit.
- the plastic handle that goes on top of the tube (includes nut and screw to retain)
If anything is missing, your best bet is to order replacements through pelican.
I’ve never needed warranty work, or preventatively maintained much. The swivel caster feet ride on bearings that could probably use a clean and lube every few years.
Apart from that, use and enjoy.
if you want pics of something, let me know.
mbunimog
Frederick, Maryland
I ordered the AC DK20HLQ from Pelican. It is on backorder but hopefully will ship soon. I have two other jacks but this one will lift higher, quicker, extend further, and go under lower cars with more control. Looking forward to receiving it
Kaline74
I recently replaced my nearly 30 year old Sears Jack with an Arcan, simply because my cars sit too low for the 4 3/4” Sears unit. I was getting by with driving my Corvette on cut 2x8 until I “launched” two of them down my driveway across the sidewalk.
So far, I am happy with the Arcan. It has a 2.75“ to 24” working range. The drop mechanism is pretty good.
Qualitytools
SOCAL
Is anyone selling the Compac here in the USA?
16again
Boynton Beach, FL.
You won't regret this purchase!
demarpaint
Long Island
I find using words like best on forums like this can get you in trouble. I have a 4 ton HF jack that's a beast and has served me well so far. I won't use the word best though, I'd rather not get involved in a **** storm. ;)
bubinga
I am from Denmark originally so it made sense to order the AC jack to support the old country
Did you get the 20 or the 13?
Ok, you got the heavy duty 20 it looks like almost 2 and 1/2 ton capacity correct?
I got the standard duty 20 I think it is like ~1.3 ton capacity.
I like it but finding it a little bit hard to jack up my Pontiac Grand Prix at the front cross member but I only use it a few times.
I started out with the handle in the full upright position though it might be easier to jack it from a more horizontal position then I have been using.
I still have to try it the garage was a little too crowded too comfortably try it as I was advised.
bubinga
Yes the heavy duty 20HLQ AC jack. It is expensive
Ok, got it.
It has the ~heigjt of the 13, with the capacity of the 20.
I get a little mixed up with all these different models but in other words I have the standard duty 13 which has approximately the same height as the one you're getting but yours has a higher weight capacity.
The DK20HLQ has a maximum jack height of 31.5 inches, the perfect height for high ground clearance vehicles such as SUVs and vans.
( And yours is ~2.2 tons )
MJK
Tucson, AZ
Just a heads up, there are more differences than just weight between the 13HLQ and the 20HLQ. They do the same thing, but the arm/beam is thicker on the 20. So, it won't slide under low sports cars as far as the 13 will. Let me know if you need a photo and I'll try and get one.
RickyPetite
Buck's County, PA
Nothing competes with AC Hydraulics for automotive use. Definitely a buy it for life kind of jack.
Agree. I have a DK20Q. The saddle is low enough to get under all my vehicles. Love the foot pump to raise the saddle quickly. Smooth mechanism. Heavy and well built.
merkyworks
Texas
MJK
Tucson, AZ
^^ pretty cool idea, but there is not enough money to get me to crawl under there without a LOT of additional support.
