Best Philips screwdriver?
craftsman47
I have had Great luck and experiences with the Craftsman blue electricians style philips with the rubber grip AND the Craftsman Professional philips.
The Craftsman standard screwdrivers are junk to me.
What is the snap on Pozi drive?
and how does that compare to their regular #2 philips?
I had a set of Williams, I was NOT impressed with the performance. It wasnt anything significantly better than the better Craftsmans to me.
I wonder if the williams really is the same as the snap on.....I have my opinion.
thoughts?
Dr.JohnnyFever
Pozi-drive is a drive type. You can kinda use a phillips driver in a pozi-drive screw head - but not the other way around.
oldldh
Fairhope, AL
I bought the Proto Classic Professional Screwdrivers...
The J9600AC 6 pc set is about $ 55.00...
The J9600CC 8 pc set is about $ 68.00...
I think they're the best screwdrivers I've ever used, and they're made in the U.S.A....
Brownsfan
Cleveland Ohio
There is no best. This is VERY subjective. Everyone is going to have a different opinion. I own Snap On, Proto, Klein,Cornwell(Witte)and Craftsman Phillips drivers. The best fitting Phillips driver out of the all the drivers I own the German Cornwell(witte made). They just grab the screw the best. Not the best handles of the bunch that goes to Snap On instincts.
Solemn
I'd go with WITTE, well worth the money and you'll break the bit before you ever strip the screw
HubbaBubba
I like Klein because they are easy to obtain and I wear screwdrivers out frequently from daily use.
arz71
Arkansas
Like either Snap-On, MAC have have a few Matco (newer ones) they are NICE. Thinking they are Witte made in Germany. Germany does have good tools.
Dick in Wisconsin
Shawano, Wisconsin
Any pro brand with a handle you like, replace often.
Very profound.
I think the Phillips head screw was purposely designed to destroy the screw driver over time. At the first sign of wear on the Phillips screw driver tip, the tool should be destroyed and immediately replaced. Cut the end off and toss it away. It will only get worse!
doan
Frisco, TX
Very profound.
Only spend big money on the Philips #2, the rest don't really get used hard. Even then most of the "hard" tasks are done by drill/drivers with replaceable tips.
I have drawer full of craftsman that get used for lots of non-screw-driving tasks.
C
craftsman47
i see 4 part numbers. bit confusing.
9T 63501
9T 63035
9T 53035
9T 63502
looking for #1 4 inch
and #2 4 inch phillips
C
craftsman47
MAXXPRO PLUS PHILLIPS SCREWDRIVER
$5.17
Qty 1
Cancel Item
Sold by Sears Item # 00940576000 Mfr. Model #9T 63031
$15.53
Qty 2
Cancel Item
Sold by Sears Item # 00940609000 Mfr. Model #9T 63035
MAXXPRO PHILLIPS SCREWDRIVER
$15.53
Qty 2
Cancel Item
Sold by Sears Item # 00940623000 Mfr. Model #9T 53035
MAXXPRO PLUS SQUARE SCREWDRIVER
$13.80
Qty 2
Cancel Item
Sold by Sears Item # 00940577000 Mfr. Model #9T 63061
16 bux out the door.....with my points. THANK EDDIE LAMPERT.
1950mercury
metro detroit
What Williams set did you have. Did they have the acr tip on the Phillips. Once you use an acr tip Phillips You will be sold on them
arz71
Arkansas
$5.17
Qty 1
Cancel Item
$15.53
Qty 2
Cancel Item
$15.53
Qty 2
Cancel Item
$13.80
Qty 2
Cancel Item
I do like the handle on the Witte, excellent design.
The slim line snap-on screw driver handles I did like them but they stopped making them.
Wamsutta
Amarillo, Texas
9T 63501
9T 63035
9T 53035
9T 63502
The 53035 doesn't have microfiber flocking, but the 63035 does.
The 63501 is a #1 with hex bolster and the 63502 is a #2 with hex bolster.
Industry standard will always have the #1 phillips with a 3'' shaft and the #2 phillips with a 4'' shaft.
The 9T is a Sears prefix.
Fedwrench
Valley of the sun
I can't narrow it down to just one so, here's my top 3 or so:
Snap on hard handle P#2 with a 4 inch blade. It just seems to fit screws better.
Old style Wiha microfinish with the hex blades. Simply the best nonslip handle available. sadly, they don't make them anymore. Not to be confused with the cheap round blades available today or those hideous striking cap models :wtf:
Proto Duratek screwdriver with the heavier bolstered blade. Quickly becoming my reach for first screwdriver. :thumbup:
The German made NAPA blue and yellow handled screwdrivers. Not the current Carlyle ones, the ones before that. Think Witte without the flocking. I'm not a fan of the flocking, gets dirty and stay dirty. I've worn some of it off on the first generation Matco drivers from like 10 years ago.
But honestly, my favorite P2 screwdriver is my tiny snap cordless CT561 screwdriver. I hardly ever use a regular screwdriver any more. It's really small and strong. I haven't found anything comparable in it's size. Mine is so used, the red snap on paint is worn off and it's just dinged up black now. I had to replace the 7.2 volt batteries because they lasted less and less time on a full charge. :beer:
Mark in Indiana
Southern Indiana
I also like the C-Man professional Phillips. The other day, I bought a C-Man professional 6 in 1 that's much more comfortable than their standard model.
C
craftsman47
What was is that you did not like about that set? Did they fail after so long? Did the tips break off? I have tht set and they are very nice no problems.
the Philips did NOT bite as good as Craftsman Professional on my stuff....
d.mcfarland
Western PA
First question. Are you biased at all in your thinking? Be honest.
Second question. Did you compare the fixed blade models to the 1/4 hex bit driver options?
JUNK-MAN
PA
I only use Snap-On hard handles I recommend them when I can they are great screwdrivers.
Solemn
9T 63501
9T 63035
9T 53035
9T 63502
Warranty from matco is entire driver, handle and all. As far as I could find there are only 8 non isolated sizes, I know WITTE had their website but I don't do much beyond what the 8 pack from matco offers
Manny2_0
Wera are high quality with a very reasonable price and great ergonomic handles. Love the Chisel Drivers.
I got a small set of the wera chisel drivers, made in Czech
The Phillips just fits so nicely in screws:bounce:
Haven't used it much but a cam out is harder because of such a great fit.
Better than my craftsman pro's
they are hex shaft, and bolstered, 1/4 in square in the strike cap for a ratchet if you ever want to get retarded :thumbup:
handle wise to me the craftsman pro's take it by a nose:3gears:
Flange
Northern England
I agree-ish. You need to think of Pozidrive and Phillips as being totally different in the same way Torx and Hex socket head screws are different.
If you use the wrong type driver you will, most likely, mash up the screw head.
damienga15de
The op was driving pz2 screw with a ph2 driver. Iv got Pb Swiss and wera screwdrivers I'd rate the wera better.
Wizzard
I've had good luck with the SO hard handle type, I personally prefer the ACR versions.
