Best PVC Cutter?
CBassB
Canada
My pick would be Uponor, made in France last time I checked. Very good quality.
Ohmthis
Outside of Louisville KY
Not sure what the largest size is that you’ll be cutting. Not that it matters. I have rigid and have used the hell out of them. I’m not sure where they were made. Sorry I can’t help you out more.
Chucktin
I have seen a PVC cutter that resembled a lightweight copper tubing cutter, rollers, anvil with blade, and screw handle. THAT's the one I want.
driftpin
Need to replace a broken PVC cutter from Horrible Freight. Looks like Ridgid has moved to China. Is MCC the best bet now? Looks like a decent tool imported from Japan.
http://www.mccusainc.com/Tools/PVC-Pipe-Cutters.htm
EDIT: Thread titled "PVC" cutter..... should have said PEX, CPVC, and PVC... 3/8" and up.
Thanks,
I've had an mcc PVC cutter for probably 40 years. They invented the ratcheting split-anvil PVC cutter. I've replaced a few blades along the way, but it's lasted 40 years, so I'd say they have a good design.
The Knipex looks heavy-duty, I'd hate to pay their price, I'm sure it's $$$, I haven't looked, because I already have several PVC cutters, w/the mcc being the one I've had the longest. I still have the box it came-in, too.
Showkey
"MEMBER EMERITUS"
Wausau WI
$103 on Amazon over kill for DIY guy coming from HF
Knipex has some other designs for $40-$60.........plenty of decent tools like MCC tools in the $20-30 range for a DIY casual use.
xin
ARKANSAS - NWA
Does it rotate the PVC as it cuts it or does someone got image of how this tool works?
thanks
ChrisLS8
I used my friends M12, simply enjoyable. Ridgid is well built regardless of COO and will serve you well
A
AmericanMechanic
Thanks, will probably go MCC. Knipex looks interesting, but as the poster above said it is probably overkill for a homeowner with MCC being half the price.
6PTsocket
Do you need the BEST? Unless you cut pvc all day long something like a 125 buck Knipex is overkill. I bought the Dawn Industries R125 ratcheting cutter. It is glass reinforced nylon, around 30 bucks and sold in the irrigation supply stores. Those guys cut a lot of tubing, in the dirt,4 so it must stand up. The blade is replaceable. I've cut PVC and a lot of other hose and tubing and it works very well. I got mine from some some outfit selling on Amazon but it is readily available
