flippin
Interesting, mine are Taiwan....
I also bet they have a black finish instead of chrome. If I am not mistaken all of the black finish Proto wrenches are imported..
Proto, Made in Texas!
I used to have Gearwrench but once I got my first set of Facom ratcheting spanners I ended up selling the Gearwrenches and buying 4 sets of Facom ratcheting spanners.
6-24mm reversible
6-19mm zero offset
8-19mm flex head
8-17mm stubby reversible
The Facom's are in a different league compared to all the others I've used. They really are that good IMHO.
I've got gearwrench reversables and gearwrench 0 degree offset stubbies. I love both of them and use them professionally.
I don't know if I hate you or you are my hero, nice setup, sir!
Do they make PROTO ratchet wrenches in metric and SAE? I see your set is spline drive, I'm looking for NON-spline, USA made ratchet wrenches...
Do you guys use a conventional wrench to break loose a tight fastener and then switch to a ratcheting wrench to remove?
Are ratcheting wrenches only for light use?
I have the GW flexheads metric set I purchased from Amazon. Retaining collar on the 15mm ratchet end came off straight out of the box. Took APEX 30 days to replace it under warranty. So if you make a living with your tools you may want to source them locally with someone who can replace them quickly.
6-24mm reversible
6-19mm zero offset
8-19mm flex head
No SAE?![]()
Facom 467! Very slim design! I adore these wrenches because of their very low arc swing and a thin ratchet head design! The satinfinish is great to, not like stahlwilles, but better than polished chrome that is like a wet soap in your handsI dont get the idea to build a tool so slippery...I know its a benefit when you are cleaning it, but i doesnt se any problem at all to clean my satin tools, little harder to vipe clean maybe.
Any suggestions on best place to buy Facom? I am specifically interested in the 467AS. Thanks!
I see you have the old version of facom ratcheting wrenches, perhaps you know if they has the same mechanism like the new version? Only curious what the difference is because they look like a complete other wrench to my 467![]()
Yes the finish is superb on stahlwille! Not so US shiny, but after abusing them hard, they has the same finish efter a lifetime of wrenching
