Best tool to remove this spring?
tommydog35
I need to replace a spring the same as the one in the photo. It's inside a welded door panel, so will need something quite long to reach it. If I can do it in situ, it means I won't have to disassemble / remove all the lock mechanism, and it will save me time. I thought about using a pick, but I think I would like more control than a pick offers, plus if the spring fall's it will be a pain to recover. The spring is only about 20mm long, so I need something quite intricate, but long at the same time. Are there special pliers for small springs? Does anyone have any links for tools that may be useful?
LXCam
Just yesterday I made a tool that would work perfect for that. Pro tool has a set of picks that are about 9" long and not too small in diameter or too big. I took the one that had the 90 degree end and heated it red hot then bent in over. Then I went over to the belt grinder and ground down the tip so I was left with only about 3/16" return with a 1/8" inside diameter of the bend. I used it to reach thru a spark plug boot to pull the crimp assembly in, worked like a champ.
Stuart in MN
Minneapolis
Can you reach in and grab it with a pair of long nose vise grips?
firworks
IL
This is probably the best bet. Picks are sort of a tool blank that you can shape into whatever you need! You'd need longer ones but I've bought the little orange handle sets of picks from HF to modify and make specialty re-pinning tools for automotive connectors. They're strong and work great and save literally hundreds of dollars. Find some long ones and get to work shaping exactly what you need.
LXCam
Do you need to pull or push it off. If pushing it off I have a couple flat blade screwdrivers I ground a grove into the tip for just such occasions. Just make sure the shank is strong enough not to flex on you.
OP, if you want PM your number and I'll text you a picture of what I made yesterday.
snyder
Baltimore md.
Tie a loop in a piece of weed trimmer line and feed it down through the window slot.
Hook it over the spring and lift up and off.
LXCam
To reduce tension on the spring extend it as much as you can and slide coins in between the windings.
I gotta say I'm not a young fugger and I've never heard or ever thought about doing that, but that's a damn good idea for certain types of springs :bowdown: :thumbup:
PassnThru
Bowling Green KY
It's handy for return springs. Open fully and insert coins - close in a controlled fashion and many springs will just fall off for you no matter how tight they were to start with.
slip knot
Texas gulf coast
One trick I learned many years ago is that 1/8 in 7018 welding rods make great picks. beat the flux off with a hammer and heat/bend/grind/shape it however you want. its tough and stout. I've got some that are 20+ yrs old and not even rusty.
If you want to get fancy get some 3m weatherstrip adhesive and glue a strip of vac tubing for a handle.
Grant Gunderson
Bellingham, WA
I took a really long screwdriver and ground a notch in it for the exauhst springs on my sled and it worked great the notch really helped when you need to reinstall the spring.
firworks
IL
I used to use these tools when working on teletypes in the '70's. Very good for removing and installing small springs in confined spaces.
Spring Hook
Those are very cool and look really handy. I think I'll order a couple for the future. Never know when they'll save the day.
wssix99
Chicago, IL
I was thinking 12" locking hemostats.
I've tried hemostats for this type of thing and the jaws break. (The pulling force is just too much for a spring.)
I like the idea of having a pull wire to grab the spring if it falls. I use extra long needle nose pliers for things like this.
T
tommydog35
That's a really great tip. I could put a few coins in there and then just fit the spring in place with some medical pliers. This would save having to mess about gripping the spring to tension it in a limited space. It would also remove the tension from delicate surgical pliers, which may not be heavy duty enough to overcome the power of the spring.
ryan20021982
Northern IL
Use an old large head flat blade screwdriver and cut a slit in the middle and use it to push the bottom of the spring off, I have 2 different lengths of these that I use just for springs. They come in handy if you have recessed lights to put the spring covers back on after cleaning or changing bulbs.
ricleh
Sacramento, CA
Used them on the UGC 74 more than once. Do you still have a set of tuning forks?
Never worked on a UGC 74. I believe they came along after I left the military in 1975. I worked primarily on Teletype Corporation Model 28 and Model 33 units (ASR, KSR and RO models). I also worked on some Nixdorf ****. Never used a tuning fork. The Model 28 machines had hundreds of springs and a couple thousand moving parts. They were built like tanks. They ran continuously until parts broke or wore out and then we would fix them and put them back in service. The Model 33 was a much less robust machine than the Model 28, but still much better than the Nixdorf portable machines I worked on.
gungatim
west mich
interesting someone else knows what a teletype is (was). we had one in our basement forever, it was a green WU model 15 I believe. had a big RF box underneath for the receiving, I think it was an add on (modem?). the tuning forks were for speeding the motors up due to British ones being a different baud rate during wwII (what I have read).
interesting tidbit of trivia, development of reusing these machines for the deaf is what led to the invention of closed-captioning we now have on televisions...
sorry to go off topic!
Abeo
Calgary, Ab
T
tommydog35
I made a little pick from some old scrap which clamped round the body of the spring. I then put washers in the spring to extend it. Using this method it was really easy to line it up on the vehicle and once lined up I just used another pick to pull the washers out. Thanks for the tips guys, as it made the job really easy.
Here is a picture of the pick with the washers in the spring:
[/url]
