Thanks Cyberbear. I started researching that but got busy so will dig deeper. I am fortunate that I have no building codes on non-living dwellings in my town, so no stamps required. I figure about any steel beam will at least hold everything up, and then if i start to notice a sag I could always weld some additional support to it of some sort. As I'm going through different thoughts or possible issues, I'm thinking that I should leave the beam at least 1/2" to 1" short to deal with expansion/contraction of the building due to the temp changes, that way it doesn't bulge my walls. Does this seem to make sense?
the bldg codes are not your enemy thay are base on simple engineering principal, so by not using the codes, is an accident waiting to happen. even if it doesnt get inspected the bldg codes will tell you everything you need to know on clear spans
Bill, it looks like he ended up with a W12x45 and packed the web and used joist hangers. For other people considering this it is easier and less expensive to bolt a plate to the top of the beam and use top flange hangers. There is wood all the way to the edge of the deck to nail the sheeting to also.
Nice job, looks great. Glad you posted a follow up and not leave the reader hanging! Are you going to fabricate a permanent stairway to the intermediate level or just use a ladder? Also, I'm not grasping what those white holes in the beam are, if they are indeed holes![]()
Kudos for solving the problem but I'm a little puzzeled. W16x122 is a bad number. No such thing. In my business we are not allowed to burn bolt holes. They have to be drilled or punched. Out on the job all kind of things can happen however. By putting the plate on top you can use a 2x4 or 2x6 and then use top flange hangers. Much easier and less expensive. We usually send the beam out with holes drilled top and bottom for the framers to bolt on the plate with carriage bolts. The bottom plate is for the drywall guys.
You came up with a great solution. Now you can fab some nice steel guardrails and weld them to the top of the beam.
I don't recall if you said you had inspections where you are. If you do keep in mind that the steel beam may need to be covered in drywall for fire resistance.
I would install one row of solid bridging at the midpoint of the joist spans.
In not fancy terms, what do you mean by this? Nailing a piece of 2x12 between each joist? I don't plan to do any sort of ceiling cover here so I probably should have SOMETHING there
It should probably be called blocking.
It helps distribute loads across the floor deck by providing lateral support to the floor joists. It would also help to do this where the joists bear on the ledger at the back wall. A detail I would have used, is to have run a 2x12 ledger across the back wall and then hung the floor joists from it with joist hangers. The ledger would have been lag bolted to each stud. This way there would be no ledger hanging down, interrupting the wall finish.
How is the ledger attached and how are the joists attached at the wall?
Bill
