Parabellum
- Joined
- Mar 6, 2014
- Messages
- 888
What is the best way to remove black sharpie writing from a
red Proto socket box?
Thank You
Thank You
Rubbing alcohol should do it.
Dry Erase marker will remove the permanent marker
Its true. I didn't believe it, but I tried it myself.
Acetone
Bingo. Sharpies are alcohol based, so you can easily use isopropyl alcohol to remove it. Any distilled alcoholic beverage over 100 proof should work too.
Ehhh yeah it will do it. But it also takes off certain paints like nothing.PVC cleaner will do it, BUT try a small spot first.
WD 40 and a Magic Eraser, guaranteed. Won't harm the paint.
Dry erase marker is the way to go. Safe & easy!
beat me to it, this worksWrite over the Sharpie WITH a Sharpie. Wipe off when wet. It's a trick I have been using for years.
I use the same
