Big level storage
eric_koski
Connecticut
Don't see many ideas for storing long levels. I have several including a couple over 5 feet long. Those get moved around the shop for lack of a permanent home. Let's see some great ideas for a rack or similar.
Stuey
28m above sea level
I know this is bad advice, but my 4' level is in a plastic case and under the bed. 4' and longer tools and equipment are all somewhat awkward to store. I usually keep them all clustered together vertically in a corner. You could also put up shelf brackets but no shelf.
Ascinder
Reno, NV
Large diameter PVC or ABS pipe and some screw on endcaps like just about any contractor uses. Been storing an 8ft CRL straightedge in them for about 8 or 9 years now. Keeps the dust and moisture out and is somewhat shock resistant.
boiler7904
NW IN
I had the same dilemma when I bought a 59" Stabila last year and realized you can't get a case for it that doesn't have a pocket for every other shorter level Stabila makes.
Here's the solution I came up with.
I use a piece of 3" PVC pipe that has a glued on cap on one end. Cap has a small piece of foam for padding. The other end has a threaded adapter and threaded cleanout plug - also with a piece of foam for padding. I added an eyebolt through the cleanout plug for hanging the whole thing from a hook - but so far it just stands in the corner of my garage.
mdbeck1
Norman, OK
Add a piece of foam rubber to each end and it will help with the shock and keep it from rattling. Of course if that foam rubber ever gets wet....
slow50
mine hangs on the wall too but a little lower tech its just on a nail.
signcrafter
I have a small section of peg board on the wall with a few hooks on it. It has about 6 stabila levels on it and a bunch of metal straight edge rulers and a few other things on it. You don't need a whole sheet, just big enough to put enough hooks in it for what you need.
blasto9000
Los Angeles, Calif.
I put two long screws in the wall way up high, near the ceiling. Keeps levels out of the way but they're not too handy (garage has 12' ceiling). I only use them once in a while though.
jkeyser14
(rural) Maryland
Out of curiosity, why do you need a level that long? Most people don't realize that a long level is just as accurate as a short level (normally .0005" over 1'). The only thing the long level does over a short one is ignore any waves in the surface you are measuring that are shorter than the short level. If you just use a 2' level and check in two places you get the same result for a lower cost and easier storage.
For spans longer that 2' of course. Think house framing where a 4' spacing is not uncommon...
mobiledynamics
Gotham City
I have the the whole kit kabodle just stored right behind a door that does not get closed.
I do have 2 I need to decide. Probably plan to just rack them on the wall horizontal.
Eight Footer and some new tracksaw guides. The tracksaw guides I've been thinking as one guide is 9' and I plan to baby it to keep it from bowing
Brad54
My Craftsman 4-footer has a plastic case, with a eye on top of it. I just hang it on the pegboard between my two single-bay garage doors.
Great use for an awkward spot on the wall.
-Brad
Rust
The Path of Least Resistance
:thumbup:
Why bother with a 2' level when you can use a torpedo level and carry it in your pocket, you get the same result for a lower cost and easier storage.
sselander
CT
