The cord and plug act as the disconnect.
You can't hook the hard wire the cord directly to the power
Best to check with your inspector on this. That was my plan and the inspector would have none of it.
During electrical I wanted to put a plug box on the ceiling to plug the gas heater into later. Inspector asked what it was for and said he wouldn't pass it when time came. I had to coil wire up in the attic and pull it through the ceiling when the heater was installed. For a disconnect, a standard light switch with red "emergency shut off" plate will suffice if you planned for it during your electrical rough-in. Otherwise you can mount a disconnect box right on the heater.
FYI: When I asked the inspector "Why not?" he basically told me that a gas heater is a permanent fixture and it's not appropriate to use a standard plug/outlet for a permanent fixture. When I pressed him on it, he said that it could vibrate lose especially when installed on the ceiling, causing nuisance calls and potential arcing.
I personally think using an outlet would be fine, but speak with your inspector. If nothing else, you may want to consider a twist-lock plug.
Another note: By code, the heater is supposed to be on a dedicated circuit. If your inspector doesn't give you a hard time about using an outlet, he may give you a hard time about the dedicated circuit. Assuming you're going to need/involve an inspector tho
Oh, and to answer your question: My 85k Big Max is rated at 4.7A or roughly 500W. I'd expect yours to be similar or slightly less.
