DandyDon
Thanks for the reply and for all the help provided. After doing a lot of research and watching several videos on these old Quincy compressors I feel like I got a great deal when I purchased it. These old machines were well made back in the day to last 50+ years.Hi,
i'm glad it all worked out. That extra port in the unloader tower is likely for a dual unloader setup for continuous run. Since you don't have 2 unloader towers your compressor probably wasn't specd for it. You can just plug it and make sure it doesn't leak and work it's way loose. Loctite would seal the threads and make sure it doesn't loosen up over time if you have a bottle around...
Thanks again Joel!
DandyDon
